1957 Chrysler Data Tag Letter CodesJump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
| Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet Decoding | Message format |
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . All of us know how to decipher Detroit-built 1957 Chrysler Data Tag codes; It’s most easy to understand: the optional order codes just stamped on the tag. I did my little “investigation” about letter “ABCDE” codes located in the lower row of these tag; A9 – order code 359 – Insert Moulding: optional on Windsor and Saratoga, not available on New Yorker or 300C; C2 – order code 562 – Sweepspear Moulding: optional on Windsor, standard on Saratoga (single) and New Yorker (dual) So, Two-tone painted Windsors (roof and insert – in same color, body – in another one) should have A9 code on the tag; Two-tone painted Windsors (roof – in one color, body – in another one) could have C2 code on the tag and no A9; Single-tone painted Windsors could have C2 code on the tag (and no A9) as well; Two-tone painted Saratogas (roof and insert – in same color, body – in another one) should have A9 code on the tag; Two-tone painted Saratogas (roof – in one color, body – in another one) couldn’t have A9 or C2 codes on the tag – (C2 is standard); Single-tone painted Saratogas couldn’t have A9 or C2 codes on the tag as well; I posted some pictures with “A9” and “C2” codes and I hope my “investigation” was correct… More pictures in same format (car / data tag) would be appreciated… I’ll start with Saratoga; Paint XAX – two-tone paint with insert: the code “A9” shows that the Insert Moulding is present! (1(1).JPG) (1(2).JPG) Attachments ---------------- 1(1).JPG (26KB - 402 downloads) 1(2).JPG (36KB - 396 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Paint XPX – two-tone paint with insert: the code “A9” shows that the Insert Moulding is present… (2(1).JPG) (2(2).JPG) Attachments ---------------- 2(1).JPG (83KB - 401 downloads) 2(2).JPG (39KB - 416 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Paint XTX – two-tone paint with insert: the code “A9” shows that the Insert Moulding is present… (3(1).jpg) (3(2).jpg) Attachments ---------------- 3(1).jpg (34KB - 381 downloads) 3(2).jpg (49KB - 380 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Paint A – single-tone paint: no code “A9” – no Insert Moulding, Single Spear Moulding is standard… (4(1).JPG) (4(2).JPG) Attachments ---------------- 4(1).JPG (56KB - 395 downloads) 4(2).JPG (142KB - 361 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Paint SL – two-tone paint: no code “A9” – no Insert Moulding, Single Spear Moulding is standard… (5(1).JPG) (5(2).JPG) (5(3).JPG) Attachments ---------------- 5(1).JPG (47KB - 404 downloads) 5(2).JPG (64KB - 393 downloads) 5(3).JPG (56KB - 375 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Now, the Windsors: Paint BCB – two-tone paint with insert: the code “A9” shows that the Insert Moulding is present (1(1).JPG) (1(2).JPG) Attachments ---------------- 1(1).JPG (84KB - 343 downloads) 1(2).JPG (54KB - 376 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Paint WAW – two-tone paint with insert: the code “A9” shows that the Insert Moulding is present (2(1).jpg) (2(1).png) Attachments ---------------- 2(1).jpg (70KB - 398 downloads) 2(1).png (241KB - 400 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Paint WX – two-tone paint: no code “A9” – no Insert Moulding, but it has “C2” code – the Spear Moulding is present! (3(1).JPG) (3(2).JPG) Attachments ---------------- 3(1).JPG (60KB - 366 downloads) 3(2).JPG (32KB - 422 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Paint X – single-tone: no code “A9” – no Insert Moulding, while “C2” code – the Spear Moulding is present (4(1).JPG) (4(2).JPG) Attachments ---------------- 4(1).JPG (71KB - 383 downloads) 4(2).JPG (99KB - 398 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Paint S – single-tone: no “A9” or “C2” codes!!! No Spear or Insert Mouldings on this car!!! Two-tone paint scheme and spear moulding are aftermarket add… (5(1).JPG) (5(2).jpg) Attachments ---------------- 5(1).JPG (50KB - 361 downloads) 5(2).jpg (97KB - 377 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . And the last example: Paint BX – two-tone paint: no code “A9” – no Insert Moulding, “C2” code – Spear Moulding – Yes! Unknown “D2”code… What it could be? Drip Rail Moulding or Dual Exhaust? Locked Luggage Compartment or Third-Row Kiddie Seat? Power Tail Gate Window? (although I see a crank on the tail gate) (6(1).JPG) (6(2).JPG) Attachments ---------------- 6(1).JPG (60KB - 382 downloads) 6(2).JPG (35KB - 395 downloads) | ||
| ToMopar |
Expert Posts: 1254 ![]() ![]() ![]() ![]() ![]() Location: D-70199 Heslach | you are very meticulous in figuring out the order codes thanks Igor | ||
| Lancer Mike |
![]() ![]() ![]() ![]() ![]() Location: The Centennial State | I wonder if you may be able to email Chrysler Historical to see if they have a decode of the ABCDE codes? Some of those could possibly be interior options. Or perhaps the broadcast sheets give a clue? Great work, Igor! Edited by Lancer Mike 2024-02-15 8:53 AM | ||
| Powerflite |
Exner Expert 10K+ Posts: 10464 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | My first Windsor was made in LA and it has no letter codes like this on it, so that doesn't help you. But my second one was made in Detroit and it does have A9 on there, which does match to the presence of a 2-tone scheme. The chopped 4dr sedan that I parted out had C2 code, and it did come only with side spears. So my 2 vehicles match what you are saying. (New Windsor Bumpers.jpg) (TrimTag.jpg) Attachments ---------------- New Windsor Bumpers.jpg (124KB - 377 downloads) TrimTag.jpg (97KB - 386 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Thanks for sharing Nathan! I had this data tag picture already, but had not the picture of car itself, so the gap is filled now – thank you! LA-built cars painted in two-tone color scheme with color insert have not any digit on the data tags; The two tone-paint scheme codes are showing this item like XAX, XRX, NLN etc. implies the presence of the color sweep molding already. Regarding the LA-built cars equipped with sweep spear moulding, this item is showing as “1” in the “M3” slot, I guess, like on the picture below. This car originally has been painted in standard two tone scheme, LESS color insert – the roof in one color, the body in other one – see the paint code HCC. Later, it has been repainted in deluxe two-tone color scheme WITH color insert, like on the picture. Thus, I can assume: M3 = 1 = order code 371 = Sweep Spear Moulding; M4 = 2 = order code 372 = Windshield Upper Moulding (standard on NY and 300C and optional on Windsor and Saratoga) http://www.forwardlook.net/forums/forums/thread-view.asp?tid=44830&... (1.jpg) (2.jpg) Attachments ---------------- 1.jpg (208KB - 402 downloads) 2.jpg (141KB - 406 downloads) | ||
| frwl |
Expert Posts: 2282 ![]() ![]() ![]() ![]() ![]() ![]() | . Zach (aka zachs58) shared his data tag picture – thank you Zach! Paint FEF – two-tone paint with insert: the code “A9” shows that the Insert Moulding is present! http://forwardlook.net/forums/forums/thread-view.asp?tid=79428&post... (1.jpg) (2.jpg) Attachments ---------------- 1.jpg (92KB - 369 downloads) 2.jpg (154KB - 348 downloads) | ||
