1960 D500
Posted 2024-02-03 9:43 PM (#633617)
Subject: 1960 D500
Would a single 4bbl carbureted 383 1960 Dodge be graced by a D500 emblem, or just the ram version?
Also, I seem to remember, that in 1960 the 383 single 4bbl Dodge received Holley carburetors and the 361 the usual Carter AFB. Is that correct?
geoffs60
Posted 2024-02-03 11:02 PM (#633618 - in reply to #633617)
Subject: RE: 1960 D500
100100
The Holley carb was a one year only ,1960 on the 383 Polara only, of course it shared a 1 year only air cleaner because of the larger neck size on the Holley.
I cant confirm the D500 option as ram car only ? there are 1960 D500 Polara owners on this link that no doubt can.
Geoff
Posted 2024-02-03 11:54 PM (#633619 - in reply to #633617)
Subject: Re: 1960 D500
Thanks, sorry, should have specified, I meant Dart, if that makes a difference. Yes, that 60 Dodge Holley had a weird feature, one year only. Something about idle adjustment iirc, but I forgot what it was.
geoffs60
Posted 2024-02-04 2:41 AM (#633620 - in reply to #633619)
100100
Pretty sure Holley was Polara only. Dart and all others got AFB 4bbl carb. Holley for that year only , has the idle control [ slotted screw ] is underneath the air cleaner stud in the carb.
Geoff
60 dart
Posted 2024-02-04 3:18 AM (#633621 - in reply to #633617)
Expert 5K+ Passed away 30th Sept 2024. You will be missed Chuck!
5000200010005001001001001002525
single 4bbl for 60 dodge d-500 , no , with a single holley it is a ram fire v-8. with ram
induction 2 carter 4bbls it was a d-500 ----------------------later
Posted 2024-02-04 12:46 PM (#633624 - in reply to #633621)
500050001000100
I thought I could find a definitive answer by checking the 1960 Dodge brochures and the 1960 Mopar parts book. I found answers but I would
say nothing definitive, but maybe confusing.
For example, I find evidence of both a 361 Ram-Induction and a 383 Ram-Induction D500 engines. ???
As for single Holley 4 bbl carbs on 383s in 1960, I found evidence of two different ones, i.e. an R1971A and an R2052A. (???)
Both of those are Holley 4160 family. I had to Google 4160 and found this
https://www.holley.com/blog/post/holley_four-barrel_4150_and_4160_ca...
I am dropping the info below and running for shelter.
Edited by 56D500boy 2024-02-04 12:51 PM
(1960DodgeD500RamInductionOption.jpg)
(1960DodgeDartEngineOptions.jpg)
(1960DodgeEngineOptions_2.jpg)
(1960DodgeD500CarburetorPNListing_R1971A_2120469_1.jpg)
(1960DodgeD500CarburetorPNListing_R1971A_2120469_2.jpg)
(CarbsUnlimitedR1971_Holley4160_2120469Info.jpg)
(1960DodgeD500CarburetorPNListing_R2052A_2128413_1.jpg)
(CarbsUnlimitedR2052_Holley4160_2128413Info.jpg)
(Holley4150vs4160Video.jpg)
Attachments 1960DodgeD500RamInductionOption.jpg (194KB - 286 downloads)
Attachments 1960DodgeDartEngineOptions.jpg (232KB - 265 downloads)
Attachments 1960DodgeEngineOptions_2.jpg (195KB - 259 downloads)
Attachments 1960DodgeD500CarburetorPNListing_R1971A_2120469_1.jpg (125KB - 249 downloads)
Attachments 1960DodgeD500CarburetorPNListing_R1971A_2120469_2.jpg (138KB - 260 downloads)
Attachments CarbsUnlimitedR1971_Holley4160_2120469Info.jpg (106KB - 265 downloads)
Attachments 1960DodgeD500CarburetorPNListing_R2052A_2128413_1.jpg (129KB - 253 downloads)
Attachments CarbsUnlimitedR2052_Holley4160_2128413Info.jpg (92KB - 253 downloads)
Attachments Holley4150vs4160Video.jpg (48KB - 261 downloads)
Posted 2024-02-04 2:24 PM (#633626 - in reply to #633617)
Thanks. That makes sense. Since the 4bbl 383 was the standard engine for the Polara and very, very few carried the D500 emblem. Weird Chrysler model/sales strategy. The more prestigeous Desoto Adventurers got a 2 bbl 383 as standard. Makes no sense at all
Posted 2024-02-04 2:28 PM (#633627 - in reply to #633617)
Dave, yes, like for Plymouth, both 361 and 383 Ram versions were available. But Sales brochures often provide misleading, incorrect information.
Posted 2024-02-05 3:36 PM (#633634 - in reply to #633627)
500050001000100
1960fury - 2024-02-04 11:28 AM
Sorry, I had to consult my copy of Willem Weertman's Chrysler Engine book to believe that both Dodge and Plymouth had 361 and 383 versions of the long
cross-ram engines available in 1960. (see below)
And then there were the Desoto 383 and the Chrysler 413 versions.
I better quit. My head is starting to hurt (again).
(You were obviously correct. Sorry I doubted you )
See below:
Edited by 56D500boy 2024-02-05 4:53 PM
(1960MoparLongRamEngineStories.jpg)
Attachments 1960MoparLongRamEngineStories.jpg (384KB - 254 downloads)
Posted 2024-02-05 9:37 PM (#633644 - in reply to #633617)
5000200010010025
D-500 was Ram induction only in 1960, on Dart, Matador and Polara, 361 and 383 versions. ( 361 and 383 were available on Dart, 383 only on US built Polara). As a Side note, the Canadian Polara came with a 361 instead of a 383, and D-500 was not available on the Canadian models. HOWEVER, if they were equipped with a four barrel, they did not get that awful Holley carb, they came with a Carter AFB. I had a Canadian built Polara for many years bought in 1974, 361-4 barrel AFB. I sold it in 1995 to a friend who still owns it.
Edited by imopar380 2024-02-05 9:40 PM
