1958 350 Plymouth, Dodge return spring brackets 2X4 setup Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
1960-FURY |
Veteran Posts: 257 | Original set or source for reproduction set, thank you | ||
Expert 5K+ Posts: 9906 Location: Lower Mainland BC | . This is NOT what you are looking for *BUT* it might help you *FIND* what you are looking for by widening the search possibilities From the 1955-58 Mopar Parts catalog, I think at least one of the brackets had PN 1851 753. When I google "1851753", it came up for a recent *but* now closed eBay auction for a 1966 era Chrysler High Performance parts catalog. In the pages shown in the auction, it showed a 1851 753 and 1851 752 bracket for the 2 x 4 bbl set up. https://www.ebay.ca/itm/334971756799 The manifolds are listed under different PNs for the 318, the RB engines (383, 413, 426 (wedge), etc) and the low deck engines (361 and low deck 383), the brackets and springs for the throttle return springs were listed as being common for all of those applications. To me that means that there is a much wider potential source of brackets than merely the 350 LB. I searched all the usual suspects for an 1851753 bracket and came up dry so your best chances will be used from any of those listed engines. Good luck. Sorry I couldn't find you an actual 1851 753 (or 1851 752) bracket. You can see them in a photo of the engine bay of a 1958 Plymouth "Christine" clone below: Edited by 56D500boy 2024-01-22 3:35 PM (58PlymouthThrottleReturnSpringBracketPN_1851753.jpg) (58PlymouthTwo4bblManifoldAndAccessoriesPNs_1851753.jpg) (58PlymouthTwo4bblManifoldAndAccessoriesPNs_1851753_Detail.jpg) (58PlymouthTwo4bblManifold_ShowingFrontAndRearSpringsAndBrackets.jpg) Attachments ---------------- 58PlymouthThrottleReturnSpringBracketPN_1851753.jpg (148KB - 32 downloads) 58PlymouthTwo4bblManifoldAndAccessoriesPNs_1851753.jpg (147KB - 28 downloads) 58PlymouthTwo4bblManifoldAndAccessoriesPNs_1851753_Detail.jpg (146KB - 27 downloads) 58PlymouthTwo4bblManifold_ShowingFrontAndRearSpringsAndBrackets.jpg (148KB - 28 downloads) | ||
1960-FURY |
Veteran Posts: 257 | Thank you | ||
JohnD |
Member Posts: 36 Location: New Jersey | Dynamic Ronovation reproduces them along with the 350 coil bracket. Pretty close to original. They usually have a tent at Carlisle. | ||
1960-FURY |
Expert 5K+ Posts: 9906 Location: Lower Mainland BC | JohnD - 2024-01-22 6:40 PM Dynamic Ronovation reproduces them along with the 350 coil bracket. Pretty close to original. They usually have a tent at Carlisle. This? http://www.dynamicrenovation.net/viewitem.php?productid=97 or this? http://www.dynamicrenovation.net/viewitem.php?productid=98 | ||
1960-FURY |
Veteran Posts: 257 | Found the correct brackets, coil bracket I have. Classic Industries Edited by 1960-FURY 2024-01-23 11:43 AM (MN3120.JPG) Attachments ---------------- MN3120.JPG (11KB - 24 downloads) | ||
JohnD |
Member Posts: 36 Location: New Jersey | The throttle return springs in the pic look exactly like the ones I got from Dynamic years ago. However, the coil bracket in the pic is incorrect for the Commando 350 but correct for a 62 300H as it mounts to the intake manifold. | ||
1960-FURY |
Veteran Posts: 257 | Correct, I will have to offer up the coil bracket when i get it. PM me if any interest? I have the correct coil bracket already. Thank you! | ||
