56 dodge steering column firewall gasket Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
hondaman1974 |
Veteran Posts: 189 Location: Northern Illinois | hello all, is the steering column firewall gasket the same between manual and power steering for 56 dodge with powerflite? according to parts book maybe the difference is between auto and manual trans? just need a confirmation, also where to find one? i have a 56 dodge with manual steering that im converting to power. thanks. Tony | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | . Tony: Not sure what you mean by "gasket". There is a rubber cover that goes over the carpet in an attempt at keeping the engine fumes, dust and weather out of the passenger compartment. The one for the manual trans cars is a bit different because of the need to accomodate the shifter tube. The blue carpet one is my car with power steering. I think that you could modify a manual "pad" into a Powerflite pad fairly easily. Edited by 56D500boy 2024-01-18 3:02 PM (56PlymouthManualTransSteerngColumn.jpg) (AfterMarketCarpetSteeringColumnInteractions_1.jpg) Attachments ---------------- 56PlymouthManualTransSteerngColumn.jpg (148KB - 29 downloads) AfterMarketCarpetSteeringColumnInteractions_1.jpg (240KB - 28 downloads) | ||
hondaman1974 |
Veteran Posts: 189 Location: Northern Illinois | dave, looks like mopar calls this a pad, but yes thats what i was talking about. dont have to worry about the shift lever hole as it will be staying an automatic. was wondering about the diameter of the large hole between manual and p.s. "pads" havent had a chance to measure both columns to see the difference. wouldnt be horrible if i had to modify, just would like to have the correct part. Tony | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | . According to the 55-58 Parts book, I think he PN you are looking for is either 1657 046 1657 051. I can't seem to find either one. You might have to try John at Big M for a good used one. Edited by 56D500boy 2024-01-18 6:04 PM (SteeringColumnRubberPad_PN1657051.jpg) Attachments ---------------- SteeringColumnRubberPad_PN1657051.jpg (148KB - 27 downloads) | ||
mstrug |
Expert 5K+ Posts: 6504 Location: Newark, Texas (Fort Worth) | http://www.chryslerclub.org/PDF%20files/GOERS.pdf check with quiery https://quirey-quality-design-co.business.site/ | ||
Expert 5K+ Posts: 9915 Location: Lower Mainland BC | . To be clear, I ended up putting my "pad" (which I called a "Dust Shield") under the carpet: REFERENCE 1: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=66997&... I thought it looked neater to have the carpet over the pad/dust shield: REFERENCE 2: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=67458&... All that said, if I could find a NOS pad, I would buy it and install it. PS: I did fix that dangling electronic signal light flasher: REFERENCE 3: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=75344&... Edited by 56D500boy 2024-01-19 3:30 PM | ||
