Replacing springs on 59 Dodge, tips? Tricks? Pointers?
jwheath68
Posted 2023-12-19 11:53 AM (#633102)
Subject: Replacing springs on 59 Dodge, tips? Tricks? Pointers?
Bought springs from Eaton, first time doing this, I’m replacing the springs and shocks, other than the actual springs what else is needed to do this properly ? Are there any things I should do while I’m there? Thanks
Posted 2023-12-21 8:48 AM (#633119 - in reply to #633102)
Subject: Re: Replacing springs on 59 Dodge, tips? Tricks? Pointers?
50001000500
Bushings, bolts, nuts, grommets, etc.:
https://www.rockauto.com/en/catalog/dodge,1959,coronet,6.3l+383cid+v...
Check brake line and hose to the rear. Read the Factory service Manual. (FSM) Shop manual. Torques, Locktite 271
What Loctite to use on suspension bolts?
For parts that need a more permanent hold, like structural bolts in a home, auto suspensions and frames, or any other heavy machinery, Loctite Threadlocker Red 271 is the answer.
jwheath68
Posted 2023-12-21 10:41 AM (#633122 - in reply to #633102)
Thanks Mark, l did end up getting the install kit with shackles and everything as well
Interesting the FSM says no lubricant at all on any it
Posted 2023-12-21 5:06 PM (#633125 - in reply to #633102)
50001000500
Yes, grease, degrades the new rubber, If using the harder Teflon/poly bushes, silicone grease might be required. Graphite impregnated bushings may not need anything.
