Homemade Coronet 57 trim
22mafeja
Posted 2023-10-02 4:55 AM (#632159)
Subject: Homemade Coronet 57 trim
5001002525
The fin front end trim is a difficult part. Either are they insanely pitted or /and are without mounting studs. I made a rh side one out of 2mm stainless steel. The lh side one is
next. The result is not perfect but at least decent IMO. And they are forever!
(IMG_20231002_111319_resized_20231002_114750156.jpg)
(IMG_20231002_111333_resized_20231002_114749915.jpg)
(IMG_20231002_111343_resized_20231002_114749654.jpg)
Attachments IMG_20231002_111319_resized_20231002_114750156.jpg (241KB - 49 downloads)
Attachments IMG_20231002_111333_resized_20231002_114749915.jpg (249KB - 55 downloads)
Attachments IMG_20231002_111343_resized_20231002_114749654.jpg (229KB - 56 downloads)
GaryS
Posted 2023-10-02 11:32 AM (#632162 - in reply to #632159)
Subject: Re: Homemade Coronet 57 trim
1000100100
I like it! As someone who used many square feet of stainless steel to recreate or improve stock '56 Plymouth parts, I can appreciate your work.
Posted 2023-10-02 1:19 PM (#632163 - in reply to #632159)
500020002000500100252525
Nice job! That's not easy to fabricate.
Posted 2023-10-02 2:04 PM (#632164 - in reply to #632159)
Subject: RE: Homemade Coronet 57 trim
500020002000500100100100100
Great job there Ralf. Kudos.
sermey
Posted 2023-10-03 11:54 AM (#632172 - in reply to #632159)
1000100100
Comparing the mirroring surfaces, must say, this is an artwork! Hats off Ralf.
Do you will chrome plate to get the brighter reflections? On stainless stell can plate directly. I think a pre copper layer may allow an easier polishing.  - SERGE -
22mafeja
Posted 2023-10-03 1:51 PM (#632174 - in reply to #632159)
5001002525
Thank you guys for your supportive comments!
Posted 2023-10-03 5:35 PM (#632178 - in reply to #632159)
50005000200010002525
Artist work, really well done
22mafeja
Posted 2023-10-04 8:21 AM (#632185 - in reply to #632159)
5001002525
Now I have a pair..
Took about 3-4 hours a piece to make.
(IMG_20231004_140200_resized_20231004_031247299 fwl.jpg)
(IMG_20231004_140307_resized_20231004_031246828 fwl.jpg)
(IMG_20231004_140406_BURST001_COVER_resized_20231004_031246456 fwl.jpg)
(IMG_20231004_144611_resized_20231004_031245993fwl.jpg)
Attachments IMG_20231004_140200_resized_20231004_031247299 fwl.jpg (204KB - 51 downloads)
Attachments IMG_20231004_140307_resized_20231004_031246828 fwl.jpg (202KB - 46 downloads)
Attachments IMG_20231004_140406_BURST001_COVER_resized_20231004_031246456 fwl.jpg (213KB - 54 downloads)
Attachments IMG_20231004_144611_resized_20231004_031245993fwl.jpg (201KB - 53 downloads)
springsweptwing
Posted 2023-10-04 11:48 AM (#632187 - in reply to #632159)
100010025
Hi Ralf,
The 58 only has one pin on the front, same part but with one of the pins broken off,
Nicely made parts though,
Paul.
22mafeja
Posted 2023-10-04 3:46 PM (#632189 - in reply to #632159)
5001002525
Strange.. the 57 has definitely two pins and two holes in the quarter panel..
jwheath68
Posted 2023-10-11 2:35 PM (#632279 - in reply to #632159)
How much can I pay you to whittle a long piece of 59 Custom Royal lower side trim for my passenger quarter?
Excellent work for sure
Posted 2023-10-11 8:08 PM (#632282 - in reply to #632279)
Ralf, I am amazed at all the parts you can make from scratch!  They look exactly like the originals too.  Well done!
Posted 2023-10-11 9:28 PM (#632284 - in reply to #632159)
50002000100100100100
Pure artwork. Beautiful.
sermey
Posted 2023-10-12 4:40 AM (#632287 - in reply to #632189)
1000100100
22mafeja - 2023-10-04 9:46 PM Strange.. the 57 has definitely two pins and two holes in the quarter panel..
For check the pins, here a similar part. - SERGE -
https://www.ebay.com/itm/402017470363
sermey
Posted 2023-10-12 4:40 AM (#632288 - in reply to #632189)
1000100100
For check the pins, here a similar part. Pictures copied as is. - SERGE -
Edited by sermey 2023-10-12 4:43 AM
(01 s-l1600.jpg)
(02 s-l1600.jpg)
Attachments 01 s-l1600.jpg (155KB - 58 downloads)
Attachments 02 s-l1600.jpg (131KB - 65 downloads)
22mafeja
Posted 2023-10-12 10:17 AM (#632292 - in reply to #632159)
5001002525
Serge ,that piece belongs to a truck. They are a little different from the Coronet 1957 ones.
22mafeja
Posted 2023-10-13 1:21 AM (#632301 - in reply to #632159)
5001002525
To fabricate a 1959 Dodge CR long quarter trim is "impossible" by hand. Only way I can think of is to mill it from a stainless flat bar and that would be costly..
jwheath68
Posted 2023-10-13 12:42 PM (#632313 - in reply to #632159)
You’re right Ralf, that’s why I’ll just end up butting two four door pieces together as others have done, no choice in the matter
Have you made any other trim parts for your 57? I always like seeing this stuff
AceS
Posted 2023-11-29 1:35 PM (#632921 - in reply to #632159)
100100252525
Tip of the hat. Great work!
22mafeja
Posted 2023-12-30 12:44 PM (#633214 - in reply to #632159)
5001002525
These were installed today. Pretty decent to be "homemade"....no studs at the moment..stainless is soo tricky to drill holes in with any kind of precision.
They sit with 3M red molding glue tape now...very strong bond.
Edited by 22mafeja 2023-12-30 12:49 PM
(20231230_161622 fwl2.jpg)
Attachments 20231230_161622 fwl2.jpg (132KB - 34 downloads)
