Dodge 1957 driver door service
22mafeja
Posted 2023-06-25 6:49 AM (#630394)
Subject: Dodge 1957 driver door service
5001002525
I had three issues with the door. It did not lock with the key. The window regulator jumped over a little in the middle of the travel. Something rattled inside the door when I shut it.
(We don`t have rattle snakes here..)
I got the locking issue solved with a minor adjustment from the outside of the door
The crank and handle removing fiddle with the screwdriver isn`t working for me nowadays due to my condition. I know I know , I should have bought a tool K-D 435 when I was young..
But that simple tool should cost me 150-200 usd including all s**tty fees....no no...
Ha.. I made a fine working tool costing me a half hour of me precious life time and a discarded plier.
The regulator had two things requiring attention. The little lip on backside that controls the axial play on the gear had got a little straightened by time and on the front side
there was too much axial movement.
I welded more material on the lip and put a oil plug copper seal ring as an axial shim. The rattle was from the gear sector plate which was eliminatedwith a coil spring between the
inside of the door steel plate and the regulator arm.
(IMG_20230625_121035_resized_20230625_125848114.jpg)
(IMG_20230625_105833_resized_20230625_125848372 fwl.jpg)
(IMG_20230625_104817_resized_20230625_125848632fwl.jpg)
Attachments IMG_20230625_121035_resized_20230625_125848114.jpg (221KB - 65 downloads)
Attachments IMG_20230625_105833_resized_20230625_125848372 fwl.jpg (57KB - 60 downloads)
Attachments IMG_20230625_104817_resized_20230625_125848632fwl.jpg (47KB - 64 downloads)
