1956 Dodge: What is the correct 3 prong flasher unit
Avanti
Posted 2023-05-06 1:18 AM (#629344)
Subject: 1956 Dodge: What is the correct 3 prong flasher unit
I posted a trouble question about turn signal problems in the past. Can't seem to find the answer. Turn signals work. All wiring checks out. The turn signal indicator flashes all the time. I want to make sure and verify I have the correct 3 prong flasher unit.
Can anyone provide correct P/N or what to use?
Thank You
Posted 2023-05-06 3:59 AM (#629345 - in reply to #629344)
Subject: RE: 1956 Dodge: What is the correct 3 prong flasher unit
50005000100252525
Jim: At this point in time, there won't likely be any OE flashers left so that is off the table. Replacement then, as now, would be a three pin 12 V Tridon, like this:
https://www.ebay.com/itm/283396417514?_ul=IL
They should be easily available at O'Reilly's, Pep Boys, etc. Nothing crazy. If you are running LED bulbs you might need the electronic version but still a 3 pin 12 V.
Your previous post with answers is here:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=78261&...
Posted 2023-05-06 12:16 PM (#629354 - in reply to #629345)
50005000100252525
A working PN for a 57(ish) 12 V flasher is 1692 716. Searching for "1692716 flasher" turns up several possibilities:
https://www.google.com/search?client=firefox-b-d&q=1692716+12V+Mopar...
Including:
https://www.ebay.com/itm/302526035682
