Front brake shoes
Vellada
Posted 2023-04-22 5:01 PM (#629063)
Subject: Front brake shoes
I am in the process of replacing brake shoes on a 1955 Desoto Fireflite. I have replaced the wheel cylinders and have installed new brake shoes. I can’t however get the brake drums back on. I have adjusted the anchor and minor adjustment cams as recommended but still can’t get the drums on. Any suggestions…. I did the same on the rear and it worked well.
Shep
Posted 2023-04-22 10:08 PM (#629071 - in reply to #629063)
Subject: Re: Front brake shoes
20001000100100100100
Unless the lininings are dead square in relation to the drum, you can't get it back on, common issue on the front. Move the linings around till they look centered on the backing plate. Second check the factory lining thickness, compare them to your new ones, seen them reclined to thick.
geoffs60
Posted 2023-04-22 10:37 PM (#629073 - in reply to #629063)
Subject: RE: Front brake shoes
1002525
check your new cylinders against the originals, i got caught out where the new cylinder pistons are not as deep where the push rod sits, which in turn has the shoe sitting further out than previous with orig w/c and the drum would not clear. Geoff
