dodge59![]() |
Elite Veteran Posts: 1018 ![]() Location: Milwaukee Wisconsin | I'm restoring a 59 dodge cr 4 dr ht .... I have a question regarding the carpet and the plastic B-pillar cover . Does the carpet go under the plastics pillar cover or on the topside of the edge at the bottom of pillar? here a few pics. Thanks ! (b pillar image 50%.JPG) (b-pillar II 50%.JPG) Attachments ---------------- ![]() ![]() | ||
chstrumpetdude![]() |
Regular Posts: 62 ![]() ![]() Location: Springfield, MO | I have a 59 chrysler 4 dr HT. Pretty sure they use the same shroud too. My 2 cents, being cut and sewn carpet I am willing to bet it went under. It would be easier to trim and provides a hold down similar to the step rail covers. These are the reasons I opted for under. | ||
dodge59![]() |
Elite Veteran Posts: 1018 ![]() Location: Milwaukee Wisconsin | Thanks for the info chstrumpetdude ! hopefully someone else will chime in .. lot of 4 door hardtops out there. | ||
dodge59![]() |
dodge59![]() |
Elite Veteran Posts: 1018 ![]() Location: Milwaukee Wisconsin | anyone else have a visual on this ? or someone can look and see what there 4dr ht c pillar looks like ? Thanks ! I'm laying the new carpet now . | ||
Finsinthemirror![]() |
Elite Veteran Posts: 1119 ![]() ![]() Location: CA | For what it's worth I went and looked at my '58 Belvedere 4-dr HT for you and the carpet in mine is definitely laid underneath the plastic BUT my car has had a replacement carpet and upholstery work in the past. It seems to me though that there is a considerable gap under the bottom lip of the plastic moldings, even above my carpet that it leaves no room to wonder where the carpet originally sat. I do believe it to be underneath.. | ||
dodge59![]() |
Elite Veteran Posts: 1018 ![]() Location: Milwaukee Wisconsin | Thanks for looking at your car . I Appreciate it ! That's the way I will install mine then . | ||
Elite Veteran Posts: 1119 ![]() ![]() Location: CA | Sure thing! I'd be interested how it turns out, when you're done please post a pic. Also where did you get the carpet and is it ready-fit or do you have to trim it to fit? | ||
dodge59![]() |
Elite Veteran Posts: 1018 ![]() Location: Milwaukee Wisconsin | so far the fit looks good . but I had stock interiors make it 1" wider on the sides and 5" longer so it will meet the corners of the rear seat . it's a 4dr ht . it would have fit just fine with there stock measurements on the sides but it still needed that 5" added length to cover the corners of the rear seat . stock interiors were real easy to work with . I recommend . | ||
dodge59![]() |
Elite Veteran Posts: 1018 ![]() Location: Milwaukee Wisconsin | here is my picture of the b pillar with carpet installed under the plastic cover . awesome ! (image000000 (12) (1).jpg) Attachments ---------------- ![]() | ||
Elite Veteran Posts: 1119 ![]() ![]() Location: CA | Looks good, great job!! | ||
dodge59![]() |
Elite Veteran Posts: 1018 ![]() Location: Milwaukee Wisconsin | Sorry for such a dark Pic , I took a few and this was the best . needed more light . | ||
