Anybody recognize the fuel filter on this Carter WCFB 4 bbl carb? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . This is on the engine in my NOS guy's 55 Dodge Custom Royal Convertible. The engine is the 1955 270 double rocker ("hemi") with a 1954 Dodge Indy Pace car factory Offenhauser intake and Carter WCFB 4 bbl carb. He apparently scored the manifold and carb at a swap meet in Turlock CA years ago. He nabbed it and almost lost it to someone who questioned whether my guy knew what he had. Apparently my guy calmly said "Why yes I do" (while smiling like a cat who had just discovered a dish of cream) and walked away with his "prize" (after he paid the vendor). I have never seen a pancake-type filter like this but my guy says that they were OE for that carb. He pointed out the drain hole (with the hex head machine screw) that was used to drain off crap and debris (and maybe water??). I would like to find out more about the filter and how it worked. Edited by 56D500boy 2023-02-01 5:27 PM (55Dodge270HemiWith54IndyPaceCarIntakeAndCarburetor_1.jpg) (55Dodge270HemiWith54IndyPaceCarIntakeAndCarburetor_2.jpg) Attachments ---------------- 55Dodge270HemiWith54IndyPaceCarIntakeAndCarburetor_1.jpg (142KB - 48 downloads) 55Dodge270HemiWith54IndyPaceCarIntakeAndCarburetor_2.jpg (148KB - 48 downloads) | ||
Lancer Mike |
Location: The Mile High City | Never seen one like it. | ||
Board Moderator & Exner Expert 10K+ Posts: 13049 Location: Southern Sweden - Sturkö island | I think I can read Moraine, if that's so, it's a GM thing | ||
geoffs60 |
Veteran Posts: 165 Location: christchurch New Zealand | I have the orig 331 hemi out of the Tim Flock car that won the 55 nascar championship in 1955.The engine is still as pulled from that car. Eng CK25 Keikhaefer corp. This eng has the same style filters, whilst not factory fitted , it appears that Carl kiekhaefer ran these on his cars, like wise he also experimented with the air cleaner filters as well , with Purolator brand being used alot.. maybe these round style fuel filters gave increased filtration with out compromising fuel delivery rates or maybe even better fuel delivery rates ? over the orig carter glass bowled porcelain filter element type that these engines typically had from the factory . Always food food for thought. I have never seen any available NOS, how ever in fairness i havnt looked that hard for them either. Geoff | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | wizard - 2023-02-01 11:11 PM I think I can read Moraine, if that's so, it's a GM thing Sven: You are correct on both counts. Last night, I took my original (not downsized) photo and zoomed in on the filter. It says "Moraine Gasoline Filter". So then I googled that name and came up with a few photos of both the sealed version that is on that "54 Pace Car" WCFB 4bbl and another version that could be taken apart and the filter element changed. In all cases, they seemed to be GM Delco Moraine (see photos below). I wonder whether the 54 Dodge Indy Pace cars used GM-based Carter WCFBs (think Buick or maybe Olds) because, at that point, there had only been 2 bbl 241 Dodge Hemi engines. That was why the 701 or so Indy Pace cars used aluminum intake manifolds made by Offenhauser - there were no factory cast iron Dodge 4bbl manifolds yet. I don't know which Mopar was the first to have a 4 bbl WCFB, maybe it was the 54 Pace car and there was nothing on the Hamtrackt factory shelves to be "borrowed" for use on the Pace car. ??? Edited by 56D500boy 2023-02-02 9:44 AM (FuelFilterDetails.jpg) (MoraineNo100GasolineFilter.jpg) (DelcoMoraineAllMetalTake-a-PartGasolineFilter_1.jpg) (DelcoMoraineAllMetalTake-a-PartGasolineFilter_2.jpg) (MoraineNo100GasolineFilter_2.jpg) Attachments ---------------- FuelFilterDetails.jpg (148KB - 51 downloads) MoraineNo100GasolineFilter.jpg (143KB - 49 downloads) DelcoMoraineAllMetalTake-a-PartGasolineFilter_1.jpg (53KB - 48 downloads) DelcoMoraineAllMetalTake-a-PartGasolineFilter_2.jpg (45KB - 49 downloads) MoraineNo100GasolineFilter_2.jpg (148KB - 50 downloads) | ||
dels56 |
Extreme Veteran Posts: 351 | Question? What is the spring attached to that is shown at the bottom of the fuel filter.?? Del Take a look at the attachment Edited by dels56 2023-02-02 9:59 AM Attachments ---------------- 198D92E0-A948-4A32-BE62-3BEC788CFA46.jpeg (238KB - 47 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | dels56 - 2023-02-02 6:46 AM Question? What is the spring attached to that is shown at the bottom of the fuel filter.? Take a look at the attachment Del: That spring is attached to the carburetor and does ???? Thanks for the 51 Buick Moraine cleaning instructions (size reduced and posted below): Edited by 56D500boy 2023-02-02 11:01 AM (55Dodge270HemiWith54IndyPaceCarIntakeAndCarburetor_CarbDetail.jpg) (1951BuickMoraineGasolineFilterCleaningInstructions.jpg) Attachments ---------------- 55Dodge270HemiWith54IndyPaceCarIntakeAndCarburetor_CarbDetail.jpg (147KB - 47 downloads) 1951BuickMoraineGasolineFilterCleaningInstructions.jpg (110KB - 44 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . So far I am not giving up trying to figure out whether having a GM Moraine fuel filter on the 54 Pace car's WCFB meant that the carb was sourced from a Buick application. I determined, from two sources that there was a 4 bbl Chrysler 331 in 1954, but that carb would have been too big for a 1954 241 Dodge V8 so the Buick source might not be wrong. Going back to the Moraine filter, I did find photos in my electronic files that show the Moraine filter on the 54 Pace Car. The Chrysler info: Edited by 56D500boy 2023-02-04 2:52 AM (CarterWCFBAdjustmentDataTableWithApplicationList.jpg) (1954-Dodge-Royal-500-Indy-Pace-Car.jpg) (dodge_royal_convertible_indy_500_pace_car_4.jpg) (dodge_royal_convertible_indy_500_pace_car_CarburetorShowingGMDelcoMoraineFuelFilter.jpg) Attachments ---------------- CarterWCFBAdjustmentDataTableWithApplicationList.jpg (149KB - 48 downloads) 1954-Dodge-Royal-500-Indy-Pace-Car.jpg (108KB - 53 downloads) dodge_royal_convertible_indy_500_pace_car_4.jpg (150KB - 44 downloads) dodge_royal_convertible_indy_500_pace_car_CarburetorShowingGMDelcoMoraineFuelFilter.jpg (139KB - 50 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . Found this just now (now I am looking for a early 50's Carter WCFB rated at 450 cfm ): "The ’54 Dodge retains all the original factory equipment specified for pace car duty. That starts with a significant upgrade under the hood in the form of a 241 cubic-inch Hemi V-8. Dodge fitted pace cars with the first four-barrel carburetor used on the recently introduced “Red Ram” Hemi engine. The Carter 450 cfm (cubic feet per minute) unit added 20 horsepower, boosting output to 170 ponies. However, because Dodge didn’t have a suitable intake manifold, all pace cars used an aluminum unit from Offenhauser, the legendary California speed shop. " REFERENCE: https://www.ebay.com/motors/blog/unrestored-survivor-54-dodge-royal-... Interesting that I just noticed that the oil bath air cleaner bottom part is not showing *ANY* indents to accommodate chokes, full size Carter glass bowl filters or PS pumps (at the back of generators), implying (to me) that the 54 Pace Car air cleaner might be a unique part (as side from the obvious paint - yellow) Edited by 56D500boy 2023-02-04 2:17 PM (54DodgePaceCar_EngineBay_1_small.jpg) Attachments ---------------- 54DodgePaceCar_EngineBay_1_small.jpg (148KB - 47 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . I found a cfm calculator and a 241 cu in engine running at 5200 RPM max and 85% efficiency (a bit higher than the normal 80% for a stock engine to allow for hemi breathing benefits) would only need about 310 cfm, i.e. 450 cfm seems too high for the little 241. A 1954 Buick Series 60-70 , Model 100, 322 cu in V8, at 5200 RPM and 80% efficiency would need about 390 cfm (still not 450 cfm). This: https://www.omnicalculator.com/physics/carburetor-cfm So I went back to the adjustment chart and noted the similarities between the 1954 Buick WCFB and the 1954 Dodge WCFB (presumably the Pace Car carb). Quite similar. Not proof but NOT denial either. Edited by 56D500boy 2023-02-04 3:49 PM (CarterWCFBAdjustmentDataTableWithApplicationList_AnnotatedHighLighting54BuickAnd54DodgeInfo.jpg) Attachments ---------------- CarterWCFBAdjustmentDataTableWithApplicationList_AnnotatedHighLighting54BuickAnd54DodgeInfo.jpg (148KB - 45 downloads) | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . More circumstantial evidence: The larger 1954 Buicks with the 322 V8 used the Carter 2082S WFCB (see listing below) The 1954 Dodge Royals (top of the line in 1954, above Coronet and Meadowbrook) were designated D53-3s, according the Jon Robinson on pg. 121 of his book "Standard Catalog of 1950's Chrysler" regarding the 1954 Dodges. The listing for Carter carburetor jets at https://www.carburetor-blog.com/knowledge-base/carter-wcfb-carbureto... lists the 2082S WCFB as a D53-3 carburetor, i.e. since the only 4 bbl Dodges in 1954 were the 701 odd Pace Cars, the Pace Cars seem to have used the same carburetor as the 1954 Buicks. This leads towards the use of the GM Delco Moraine Gasoline Filter on the 1954 Dodge Pace Cars over the Carter glass bowl ceramic fuel filters that were used later. Again, circumstantial, but, perhaps, compelling evidence. Edited by 56D500boy 2023-02-05 12:53 PM (1954Buick322V8CarburetorListing_CarterWCFB2082S.jpg) (CarterWCFB_2082Specifications_pg1.jpg) (1954DodgeD53-3CarburetorListing_CarterWCFB_2082S.jpg) Attachments ---------------- 1954Buick322V8CarburetorListing_CarterWCFB2082S.jpg (149KB - 48 downloads) CarterWCFB_2082Specifications_pg1.jpg (149KB - 54 downloads) 1954DodgeD53-3CarburetorListing_CarterWCFB_2082S.jpg (147KB - 43 downloads) | ||
