325 Water Pump Housing Gaskets
FINS!
Posted 2023-01-14 2:55 PM (#626943)
Subject: 325 Water Pump Housing Gaskets
50010010010010025
One gasket for the water pump housing to block has failed, where can you get these gaskets? For a '57 Dodge
Posted 2023-01-14 7:37 PM (#626956 - in reply to #626943)
Subject: Re: 325 Water Pump Housing Gaskets
50005000100100100100
You can get them in kits, but the easiest and cheapest way to deal with it is to cut a new gasket out of gasket material you can get from any auto parts store. Use a paper hole punch to punch the holes out. It's a smaller diameter so you'll need to keep using it until you clip it out to the right size hole. Because those gaskets are so small, you'll be done before you could finish searching for a proper replacement gasket. I make sure to keep one gasket available to use as a template to make it easier for the next time.
Edited by Powerflite 2023-01-14 7:40 PM
Posted 2023-01-14 8:47 PM (#626958 - in reply to #626943)
Subject: RE: 325 Water Pump Housing Gaskets
5000500050010010010025
I agree with Powerflite but if you were able to buy a complete FS 7790 PT-2 kit from FelPro, you would have what you need now and, maybe, for the future:
https://www.drivparts.com/part-details.html?brand_code=BCWV&part_num...
Edited by 56D500boy 2023-01-14 8:52 PM
local2Ed
Posted 2023-01-15 4:53 PM (#626984 - in reply to #626958)
500252525
http://www.waterpumpman.com/
I've used this place to rebuild the water pump in my 1957 Sierra, 325 cu in poly.
It came with the gasket so they might sell the gaskets seperate.
Posted 2023-01-15 5:48 PM (#626988 - in reply to #626984)
local2Ed - 2023-01-15 1:53 PM
It came with the gasket so they might sell the gaskets separate.
Hmm...
It was my understanding that the OP is looking for the triangular (with holes) gaskets that help seal the four arms of the 315/325 style water pump manifold to the heads at the top and block at the bottom. (???)
local2Ed
Posted 2023-01-17 12:29 PM (#627044 - in reply to #626988)
500252525
Yep, you're right about the gaskets, I forgot the water pump doesn't mount directly to the block.
Those gaskets are included in the Timing cover gasket set-Fel-pro # FPGTCS64432.
Posted 2023-01-17 1:04 PM (#627045 - in reply to #627044)
Good find Ed
https://www.napaonline.com/en/p/FPGTCS64432
(FelProGasketSet_TCS64432.jpg)
Attachments FelProGasketSet_TCS64432.jpg (66KB - 404 downloads)
Mopar1
Posted 2023-01-18 1:20 PM (#627067 - in reply to #627045)
2000100010025
powerflite nailed it!
FINS!
Posted 2023-01-20 9:43 PM (#627142 - in reply to #626943)
50010010010010025
Thanks! I didn't realize they were with the timing set, got them there.
Mopar1
Posted 2023-01-25 10:51 AM (#627228 - in reply to #627142)
2000100010025
A bit late now, just remembered that while not listed seperatly on their site, HH sells just the W/P gaskets if you call them.
FINS!
Posted 2023-02-04 11:50 AM (#627360 - in reply to #626943)
50010010010010025
Hot Heads?
Mopar1
Posted 2023-02-05 11:02 AM (#627373 - in reply to #627360)
2000100010025
FINS! - 2023-02-04 10:50 AM
Hot Heads?
Yes
dels56
Posted 2023-03-02 6:34 PM (#627997 - in reply to #626943)
10010010010025
hothemiheads.com
Del
