Lubricate push button gear shift?
brdavisboise
Posted 2023-01-07 12:49 AM (#626780)
Subject: Lubricate push button gear shift?
Does anyone know whether the Push Button gear shift mechanism is supposed to be lubricated?.... Or left dry?
Posted 2023-01-07 5:39 AM (#626782 - in reply to #626780)
Subject: Re: Lubricate push button gear shift?
50005000200010002525
No service is normally needed, but if you have access to the unit, apply a thin coating of light ptfe grease to the moving parts
chstrumpetdude
Posted 2023-01-10 10:01 AM (#626842 - in reply to #626780)
I cleaned mine out of debris and gave it a coating silicone spray since it didn't have grease before. Figured it would help on the metal on metal movement a little.
