Need help with wiper motor switch: 56 Dodge
Avanti
Posted 2022-11-27 11:23 AM (#625894)
Subject: Need help with wiper motor switch: 56 Dodge
No wiper motor in car. Got junkyard motor and off it went for rebuild. Repaired and ready to go but I don't have any idea of how to hook up the switch. I know a wiring diagram may help me but looking for any photos of back of switch and where the wires go.
Also is there a process to bench test the switch. Thank You Kindly.
Posted 2022-11-27 12:16 PM (#625895 - in reply to #625894)
Subject: RE: Need help with wiper motor switch: 56 Dodge
500020002000500100100100100
It might depend on whether you have one speed or two speed or variable speed wipers. I will go out to my unheated garage a bit later and lay under 56 Custom Royal dash and get some photos. Once it has warmed up a bit (2 C, about 36 F right now)
In the meantime, there are these:
(IgnitionWiperAndCigaratteLighter_2_small.jpg)
(IgnitionWiperAndCigaratteLighter_1Small.jpg)
Attachments IgnitionWiperAndCigaratteLighter_2_small.jpg (84KB - 64 downloads)
Attachments IgnitionWiperAndCigaratteLighter_1Small.jpg (128KB - 66 downloads)
Posted 2022-11-27 5:19 PM (#625897 - in reply to #625895)
Subject: 56 Dodge Variable Speed wiper wiring and switch details
Oooo...it warmed up to a whole 6 C (43 F??). Anyway, I went out the car (56 Dodge Custom Royal and assumed the astronaut position) and took some photos.
Mine is a variable speed wiper which has one switched power to a 5 amp circuit breaker and then four wires at the switch that then enter a bundle and head to the back of the wiper motor (no idea what goes on in there, wiring-wise)
Afterwards, I searched for and found a wiring diagram in the 56 Chrysler FSM that shows the same four wire colours and then I determined that the 56 Dodge variable speed wiper switch was 1658 759 (the 56 Plymouth switch looks the same but is PN 1658 758).
Hope these photos and diagrams help:
Edited by 56D500boy 2022-11-27 5:28 PM
(56ChryslerVariableSpeedWiperMotorWiringDiagram_small.jpg)
(56DodgeCustomRoyalVariableSpeedWiperSwitch_InSituWithCurrentBreaker.jpg)
(56DodgeCustomRoyalVariableSpeedWiper_FourWireBundleEnteringWiperMotor.jpg)
(165875956DodgeVariableSpeedWindshieldWiperSwitch.jpg)
(1658759RotatedIntoActualMountingPositionToBetterShowFemaleBulletConnectorReceivers.jpg)
(165875856PlymouthVariableSpeedWindshieldWiperSwitch.jpg)
Attachments 56ChryslerVariableSpeedWiperMotorWiringDiagram_small.jpg (78KB - 69 downloads)
Attachments 56DodgeCustomRoyalVariableSpeedWiperSwitch_InSituWithCurrentBreaker.jpg (151KB - 64 downloads)
Attachments 56DodgeCustomRoyalVariableSpeedWiper_FourWireBundleEnteringWiperMotor.jpg (124KB - 62 downloads)
Attachments 165875956DodgeVariableSpeedWindshieldWiperSwitch.jpg (115KB - 60 downloads)
Attachments 1658759RotatedIntoActualMountingPositionToBetterShowFemaleBulletConnectorReceivers.jpg (132KB - 60 downloads)
Attachments 165875856PlymouthVariableSpeedWindshieldWiperSwitch.jpg (127KB - 59 downloads)
