1959 dodge cr side body molding fasteners / clips ?
dodge59
Posted 2022-08-20 6:50 PM (#623671)
Subject: 1959 dodge cr side body molding fasteners / clips ?
1000
I'm restoring a 1959 dodge cr 4 drht and need the wide side body molding fasteners  for it . here are some pics .  I only need a few . I searched denver  fasteners , quirley  and  rj & L auto fasteners  with no luck ,     but not  quirley  et .  anyone here have a source ? overall width is  1 5/8" tip to tip.  length is 2 7/16" tip to tip .
 these are the oem clips pictures of the  .  and are  for the wide side body moldings  for the 59 dodge cr .
Thanks !
john
Edited by dodge59 2022-08-20 7:13 PM
(image000000 (2) (1).jpg)
(image000000 (2) (2).jpg)
(image000000 (2) (3).jpg)
(image000000 (2) (4).jpg)
(image000000 (2) (5).jpg)
Attachments image000000 (2) (1).jpg (80KB - 41 downloads)
Attachments image000000 (2) (2).jpg (175KB - 40 downloads)
Attachments image000000 (2) (3).jpg (138KB - 40 downloads)
Attachments image000000 (2) (4).jpg (213KB - 44 downloads)
Attachments image000000 (2) (5).jpg (143KB - 42 downloads)
dodge59
Posted 2022-08-23 10:00 AM (#623733 - in reply to #623671)
Subject: RE: 1959 dodge cr side body molding fasteners / clips ?
1000
Found this site  called loco4fomoco.com ... Has almost every fasteners you could imagine but not the  part I'm searching for  .. check out this site !   very Good !
Posted 2022-08-23 7:16 PM (#623746 - in reply to #623671)
Subject: Re: 1959 dodge cr side body molding fasteners / clips ?
5000100010010010010025
Call some of these companies: https://www.google.com/search?source=univ&tbm=isch&q=Part+%23:+B7A-5...
https://www.fabulousfords.com/detail/39299/Ford_Door_and_Fender_Moul...
https://www.macsautoparts.com/body-components/exterior-trim-and-embl...
Edited by mstrug 2022-08-23 7:32 PM
dodge59
Posted 2022-08-23 9:42 PM (#623747 - in reply to #623671)
1000
ok, will do ! Thanks !
dodge59
Posted 2022-08-23 9:48 PM (#623748 - in reply to #623671)
1000
here are a couple better pics
(image000000 (3) (1).jpg)
(image000000 (3) (2).jpg)
(image000000 (2) (6).jpg)
Attachments image000000 (3) (1).jpg (129KB - 42 downloads)
Attachments image000000 (3) (2).jpg (119KB - 42 downloads)
Attachments image000000 (2) (6).jpg (217KB - 45 downloads)
dodge59
Posted 2022-08-23 9:55 PM (#623749 - in reply to #623671)
1000
looking for that spring clip with the stud also ,, I will use on the quarters where i can get to inside of the trunk , If I can't find the other fasteners.
Posted 2022-08-24 10:14 AM (#623759 - in reply to #623671)
These guys have clips and Auveco has hundreds of clips. https://www.classicchevy.com/el-camino-front-wheel-opening-molding-c...
lozrox58
Posted 2022-09-06 3:46 AM (#624042 - in reply to #623671)
I bought mine from Roman at RJ&L Automotive.
http://www.rjlautofasteners.com/
Send him your photos
dodge59
Posted 2022-09-06 7:44 AM (#624044 - in reply to #623671)
1000
<p>I bought some spring loaded fasteners with stud from Altha on ebay.</p>
Edited by dodge59 2022-09-06 7:47 AM
(s-l64.jpg)
Attachments s-l64.jpg (1KB - 41 downloads)
StillOutThere
Posted 2022-09-06 10:45 AM (#624046 - in reply to #623671)
20001000100100
A good Fastenal store carries a number of universal clips and can order boxes more of anything in their catalog.l
dodge59
Posted 2022-09-06 11:50 AM (#624048 - in reply to #623671)
1000
fastenal did not have what I wanted..
VALCUDA
Posted 2022-10-17 7:06 PM (#624934 - in reply to #624048)
New User
Have you considered having a sheet metal shop manufacture these for you in stainless & will outlast the car.
If you order enough of them you will probably get a better deal plus other Dodge owners like myself may be interested in purchasing some. Good luck. Cheers, Alan.
dodge59
Posted 2022-10-17 7:13 PM (#624937 - in reply to #623671)
1000
Alan ,, I purchased some new spring clips with the stud on them So..... I can use at least 8 of them in the trunk area where i can get at them. so I should have enough good ones now to complete the job .-
