Floor Shifter Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Plazaman |
Member Posts: 39 | Does anyone know if anyone ever made a floor shifter for the Borg Warner 3-speed w/Overdrive? | ||
Expert 5K+ Posts: 9912 Location: Lower Mainland BC | Plazaman - 2022-08-18 12:58 PM Does anyone know if anyone ever made a floor shifter for the Borg Warner 3-speed w/Overdrive? Interesting question. Because of the design of the pre-1961 Mopar three-on-the-tree linkages, with one lever up top and one on the side, it wasn't as easy to design a floor shifter as it was for a GM or Ford manual transmission. The candidates for supply of a shifter would have obviously been Hurst and perhaps the boys at J.C.Whitney. As for the overdrive, I believe that was a cable mechanism, independent of the mechanical 3 spd shifter. Here is a photo of a non-overdrive 55-56 Mopar 3 spd manual: Edited by 56D500boy 2022-08-18 5:09 PM (JCWhitneyFloorShifterForNonMoparsManuals_1961.jpg) Attachments ---------------- JCWhitneyFloorShifterForNonMoparsManuals_1961.jpg (207KB - 83 downloads) | ||
Expert Posts: 3778 Location: NorCal | Some GM's also used the "selector" type 3-speed. I had a '54 Olds with one and I installed a Hurst floor shifter in it. The shift handle was spring-loaded to the right, when the shift handle was pulled to the left for 1st and Reverse, a lever in the shifter mechanism operated the selector lever. The Olds lever layout was different than the Mopar so I'm not sure if anybody made a floor shifter for it. An old JC Whitney or Honest Charlie catalog will tell. | ||
Plazaman |
Member Posts: 39 | 56D500BOY, you are right about the OD being a cable. I have a shifter that is ancient and possibly homemade. It works but I'm just trying to find something better. | ||
58coupe |
Expert Posts: 1740 Location: Alaska | Actually the Mopar 3 speed was changed for 57 and newer to 2 levers on the side, different than the 56 and older. I had a good quality floor shifter on my 57 Fury and it was secured to the trans. by the bolts that secured the tail housing to the main case, although I never tried, I believe it would have cleared an overdrive unit. I used a Borg Warner T-85 in my 58 Fury and had a Hurst shifter on it. | ||
Expert Posts: 3778 Location: NorCal | 58coupe - 2022-08-20 8:56 AM Actually the Mopar 3 speed was changed for 57 and newer to 2 levers on the side, different than the 56 and older. Yes, but the OP is asking about OD transmissions which weren't available after '56. | ||
58coupe |
Expert Posts: 1740 Location: Alaska | According to my info OD was still available after 56 but only on 6 cyl or maybe small v-8 cars. Plymouth and Dodge only. | ||
Expert 5K+ Posts: 9912 Location: Lower Mainland BC | 58coupe - 2022-08-21 9:05 AM According to my info OD was still available after 56 but only on 6 cyl or maybe small v-8 cars. Plymouth and Dodge only. 55-56 for sure 57-58 yup, but it looks like only Plymouth 59 some (Plymouth) 60 tumbleweeds, crickets Edited by 56D500boy 2022-08-21 1:49 PM (OverdriveApplications_55-58.jpg) (OverdriveApplications_59.jpg) (OverdriveApplications_60.jpg) Attachments ---------------- OverdriveApplications_55-58.jpg (115KB - 80 downloads) OverdriveApplications_59.jpg (149KB - 79 downloads) OverdriveApplications_60.jpg (108KB - 88 downloads) | ||
Plazaman |
Member Posts: 39 | 57 Chizler: The shift handle was spring-loaded to the right, when the shift handle was pulled to the left for 1st and Reverse, a lever in the shifter mechanism operated the selector lever. That is exactly the way my shifter is..... | ||
Viper Guy |
Expert Posts: 2003 Location: Branson, MO | I got some kind of an aftermarket 3-speed floor shifter for my '56 Fury when I converted it from a Powerflite to a manual. Too far back to remember what brand it was or where it came from but I do remember that when I installed it, it shifted backwards. Reverse was where low was supposed to be and second and third were backwards too. My advantage as it made the shifts easier pulling to second from first rather than pushing through the "H" plus my "sweetie" could nestle next to me with the shifter in third up closer to the dash. | ||
