1956 Savoy Door Handle and Window Crank Removal
cdstl
Posted 2022-08-10 2:27 PM (#623475)
Subject: 1956 Savoy Door Handle and Window Crank Removal
I would like to take the door cards off to lube up the window crank and door handle mechanisms. I understand that there may be a clip at the 9 o'clock position on the window crank and door handle to remove them.
I've looked a bit by pushing the door card in but I don't seem to see what I'm looking for. I'm not sure if there's a tool that I need to aid in all of this.
Any help on removing the handles would be appreciated.
Thanks
Posted 2022-08-10 4:06 PM (#623476 - in reply to #623475)
Subject: RE: 1956 Savoy Door Handle and Window Crank Removal
500020002000500100100100100
The official tool is the K-D 435.
If you do a search on K-D 435 and my user name
three threads come up, including "Window crank removal".
That thread has all the photos and hints that you should need to remove the handles.
Edited by 56D500boy 2022-08-10 4:07 PM
Posted 2022-08-10 5:03 PM (#623479 - in reply to #623475)
Subject: Re: 1956 Savoy Door Handle and Window Crank Removal
5000
i use a wide flat head screwdriver.
heat it up and bend it for easier access.
dont have to buy the expensive tool.
Bob has a video where you can see which side you need to put the screw driver in. If the handle is 6 oclock, you put the screw driver at 9 oclock. You can use another at 3 oclock to balance it(apply pressure from other side to "flatten" lift) and it comes right off.
https://www.youtube.com/watch?v=_E_DGl6vDEs
Posted 2022-08-10 5:07 PM (#623480 - in reply to #623475)
5000
you can also use a trim tool... Like this ...
(TOOL.png)
Attachments TOOL.png (128KB - 55 downloads)
Old Ray
Posted 2022-08-10 5:12 PM (#623481 - in reply to #623480)
500
1955 1956 1957 1958  DOOR  & WINDOW HANDLE LOCKON  CLIP PLYMOUTH DESOTO DODGE
ronbo97
Posted 2022-08-10 5:46 PM (#623482 - in reply to #623481)
2000200025
Use the KD-435. The right tool for the job. Otherwise, you'll be struggling and end up damaging the door panel.
https://www.ebay.com/itm/265791252670
Ron
Edited by ronbo97 2022-08-10 5:50 PM
cdstl
Posted 2022-08-10 10:23 PM (#623488 - in reply to #623475)
Good stuff, thanks for the replies everyone. I did manage to get the handles off, lube everything up and get it back together. I'll be getting the tool, it would have made everything go much quicker.
Posted 2022-08-11 5:01 PM (#623504 - in reply to #623475)
5000
it isnt worth taking a couple door handles off... I never hurt anything with a bent screw driver./ trim tool..
