Electronic ignition 270 red ram
Arocket111
Posted 2022-07-06 4:02 PM (#622684)
Subject: Electronic ignition 270 red ram
A while ago I fitted a Mopar electronic ignition with separate control box to my Dodge 270 still using original coil ran well but in app 500 miles blew 2 control boxes. voltages were checked and found to be correct , so today I fitted a HEI electronic ignition with coil etc integral in the unit a lot cheaper also about $45 for the unit plus carriage and import duty for me being in the uk this unit only just fits in past the inlet manifold about 1/32 clearance .also requires moving the throttle linkage rod over about 3/16 and making a new throttle return spring bracket after that slotted straight in timed up and running very smoothly I just thought I’d post this for info photos attached but I cannot make them open on the thread
Ps had one of these HEI units in my 61 Chevy C20 for 3 years
Attachments AEA0EDC0-190C-4205-AB5C-2ECA3D2B06DF.jpeg (233KB - 76 downloads)
Attachments D5DFB2E5-0BE9-4A48-9540-A9E7ED1046EB.jpeg (224KB - 62 downloads)
Attachments 25DE2194-DF84-435A-8E53-2C46B6EE1038.jpeg (208KB - 60 downloads)
Posted 2022-07-06 4:37 PM (#622685 - in reply to #622684)
Subject: Re: Electronic ignition 270 red ram
500020002000500100100
I sell a conversion kit that allows you to use the HEI module with your stock Chrysler electronic distributor and is small enough that it doesn't require you to modify anything.
http://www.designed2drive.com
You can see the bottom of it in this picture on the 361 in my '58 Fireflite.
Then there is the Pertronix II or III conversion that would allow you to use your stock '50's distributor as well. More expensive, but looks stock.
(58FF Valve Covers.jpg)
Attachments 58FF Valve Covers.jpg (172KB - 59 downloads)
Posted 2022-07-06 5:13 PM (#622687 - in reply to #622684)
Subject: RE: Electronic ignition 270 red ram
50002000200050010010010010025
Phil: Sorry to hear about your bad luck with the drop-in (for your low block 270 poly) LA engine style electronic distributor control boxes. I wonder whether the issue is Chinese made VS US made (??)
Summit Racing certainly has a wide variety of units including a PerTronix version. And then there is Nathan's well-priced HEI conversion bracket to consider.
https://www.summitracing.com/search/part-type/distributors/make/chry...
http://www.designed2drive.com/
Arocket111
Posted 2022-07-07 3:13 AM (#622700 - in reply to #622684)
Hi Thanks for the info If I have trouble in the future their is plenty of info ,I am hoping this new HEI with integral coil is going to last and is the way forward ,as I say it is running really cleanly and smoothly at the moment thanks Phil
