60-62 Chrylsler clock removal question Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Ev's62Chrysler |
Veteran Posts: 210 Location: Suwanee, GA | Anyone have instructions for removing the clock on a 62 NYer? Does radio need to come out first? Any tricks to it? Thanks, Robert | ||
Board Moderator & Exner Expert 10K+ Posts: 13054 Location: Southern Sweden - Sturkö island | Remove the speaker mesh and speaker, remove the ashtray and the radio. Sorry, it's a lot of work to remove the clock...... | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | I was able to remove and replace my clock through the speaker opening without removing the radio. A little tight to get at the mounting screws but not that terrible. Make sure you disconnect the battery or you'll get zapped from the high voltage electroluminescent connection. | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | They sure didn't make it easy. Especially if you're not so young and flexible anymore. I still need to put the clock back in my 300F but it's such a hassle. | ||
Board Moderator & Exner Expert 10K+ Posts: 13054 Location: Southern Sweden - Sturkö island | I usually change the slotted screws to umbrako or torx heads. Makes a big difference when the clock is to be mounted again. Mind the lenght..... | ||
Expert 5K+ Posts: 9681 Location: So. Cal | Never heard of unbrako. Looked it up and see that it's a brand more than a type. I suspect you mean socket head or Allen head screws like this. (socket-head-cap-screw.jpg) Attachments ---------------- socket-head-cap-screw.jpg (15KB - 96 downloads) | ||
Ev's62Chrysler |
Veteran Posts: 210 Location: Suwanee, GA | Got it out. Not too difficult. Only had to remove the speaker/grill and ashtray. Bottom clock bracket is slotted, so only needed to loosen those screws. Hardest part was removing the speaker grill so as to not scratch paint. It's slightly bowed due to holding who knows what: coffee mugs, cigarettes, campaign speeches, etc. Took a while to orient it to that perfect position to slide it out. Will post pics later. Thanks everyone for the tips. Now the real fun begins! | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | I just stripped out a dash. It was a 1960 Windsor dash with no clock but the same screws hold in the block off. They are #8. Different from the ones that hold the rest of the trim piece. The lower screws also go through the dash sheetmetal when the trim is installed. (clock010.jpg) (clock011.jpg) (clock012.jpg) Attachments ---------------- clock010.jpg (76KB - 107 downloads) clock011.jpg (99KB - 104 downloads) clock012.jpg (71KB - 100 downloads) | ||
Ev's62Chrysler |
Veteran Posts: 210 Location: Suwanee, GA | Got the clock removed, opened, cleaned, ticking, and back in. Cleaned the plastic lens while apart. Procedure was: disconnect battery, remove speaker grill, remove speaker, remove ash tray, disconnect power and lighting leads on back of clock, remove upper mounting screw, loosen lower two mounting screws, and pull out through speaker opening. Mine used hex head screws, and I was able to use a 1/4" drive ratchet and short extension to access the lower screws through the ash tray opening. I wrapped the knob and used a monkey wrench to carefully unscrew it. Then bent the four housing tabs to remove the lens, and removed the two nuts on the rear to remove the mechanism from the housing. Points looked fine, but I lightly sanded them anyway. I used rubbing alcohol to clean the gears. Fuse is 2A, and was good. Not sure how well I cleaned it, but clock is running at the moment. Not too bad a job. Thanks for everyone's input. (IMG_4678.jpg) (IMG_4684.jpg) (IMG_4688.jpg) (IMG_4692.jpg) (IMG_4693.jpg) (IMG_4695.jpg) (IMG_4700.jpg) (IMG_4706.jpg) (IMG_4716.jpg) Attachments ---------------- IMG_4678.jpg (114KB - 100 downloads) IMG_4684.jpg (123KB - 97 downloads) IMG_4688.jpg (90KB - 93 downloads) IMG_4692.jpg (104KB - 97 downloads) IMG_4693.jpg (84KB - 97 downloads) IMG_4695.jpg (119KB - 93 downloads) IMG_4700.jpg (106KB - 96 downloads) IMG_4706.jpg (119KB - 95 downloads) IMG_4716.jpg (119KB - 94 downloads) | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | Thanks for the great documentation. Unfortunately my 300F does not have the ashtray so I'll just have to do everything from the top or pull the radio, which has been out before. | ||
