7” led headlights….. anyone using this type?
resq302
Posted 2022-03-28 1:45 PM (#620535)
Subject: 7” led headlights….. anyone using this type?
Looking to upgrade our headlights in our 57 Dodge 2 door suburban wagon. Wondering if anyone has used these plug n play headlights or heard anything about them. I know it says Kenworth tractor in the eBay add but it’s the same 7” round light like was used in the factory, only in a plastic housing and led bulb.
https://www.ebay.com/itm/Pair-7-Inch-Round-LED-Headlights-Sealed-Hi-...
Thanks for your input.
Brian
Posted 2022-03-28 2:16 PM (#620536 - in reply to #620535)
Subject: RE: 7” led headlights….. anyone using this type?
500020002000500100100100100
Those are pretty UG A LEE in my opinion. (Just my opinion)
What you might want to consider is European 7" H4 housings that accept separate halogen or LED bulbs.
I installed LED headlight bulbs in European H4 housings from California Imports (for VWs) (very inexpensive for the housings). They fit in the OE head light buckets quite well (no modifications needed with the bulbs I chose).
My thread:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=70107&...
DelS (Dels56) used a better Hella brand H4 with LEDs and I like it a lot.
This my H4 housing:
This is what DelS is running:
Edited by 56D500boy 2022-03-28 2:18 PM
(DelsHella7inchH4Headlight.JPG)
Attachments DelsHella7inchH4Headlight.JPG (112KB - 129 downloads)
Posted 2022-03-28 3:14 PM (#620537 - in reply to #620535)
Subject: Re: 7” led headlights….. anyone using this type?
500050002000100025
It hurts just to see a photo of those modern headlights.
Follow Daves advice and you'll be satisfied...
resq302
Posted 2022-03-28 4:54 PM (#620546 - in reply to #620535)
Ok. Thanks a lot. I read some of the other discussions on the ones where you have to modify the back of the headlight bucket area and I’d prefer to have to do no cutting so I don’t mess up the fender.
I’ll check out that thread now.
resq302
Posted 2022-03-28 5:40 PM (#620547 - in reply to #620535)
56D500,
I looked everywhere in your thread that you posted and I don't see any response from DelS about his light or what part number that might be or how I go about getting two of those.
resq302
Posted 2022-03-28 5:41 PM (#620548 - in reply to #620535)
56D500,
Posted 2022-03-28 9:52 PM (#620555 - in reply to #620548)
I believe DelS used Aukee LEDs. Something like these:
https://www.amazon.ca/Aukee-headlight-Lumens-Extremely-Conversion/dp...
The headlights I used were made for EMPI of VW fame:
https://www.cip1.ca/acc-c10-7590/
The place where I bought them also has European ones for quite a bit more money:
https://www.cip1.ca/c24-baa-941-751-a/
Here is an example of the Hella H4 headlights:
https://partsavatar.ca/hella-conversion-headlight-002395031?gclid=EA...
resq302
Posted 2022-03-28 9:56 PM (#620556 - in reply to #620535)
Cool. Thanks.
57plymouth
Posted 2022-03-29 6:57 AM (#620565 - in reply to #620535)
20001000500252525
Holley just released a retro looking LED headlight that is street legal. (not that anyone cares about that any more) Frieburger has them on the WW2 Jeep that he and Rick Pewe are currently driving from Arizona to Key West. They give them good feedback.
resq302
Posted 2022-03-29 7:53 AM (#620566 - in reply to #620535)
Yeh, I checked into those. Holley wanted $199 per light !
resq302
Posted 2022-03-29 11:43 AM (#620569 - in reply to #620555)
56D500 - What leb bulbs are you using? I know you said that your heat sinks fit in the opening really well and I'd like to use them also.
Posted 2022-03-29 3:33 PM (#620581 - in reply to #620569)
resq302 - 2022-03-29 8:43 AM
I had followed the lead of BigBlockMopar:
https://www.bigblockmopar.nl/2018/04/led-headlights/
Sorry, now I can't find the cheap ($30/pair) Chinese ones (the ones in the black "LED Headlight" box) on eBay now (4 year later) but I know the expensive "SuperNova" bulbs from the USofA also fit in the housing because I said this back in December 2018:
"The photos below have the cheaper Chinese H4 LED bulb in the passenger side and the expensive SuperNova Retina-burning LED in the drivers side. One low beam photo and one high beam photo. Both me and my car enthusiast neighbour like the cheap Chinese LEDs better. None of the photos show what reality is actually like."
That said, they look like these ones:
https://www.wish.com/product/5c46952589a5d5377ffced35?hide_login_mod...
Edited by 56D500boy 2022-03-29 3:49 PM
resq302
Posted 2022-03-29 4:08 PM (#620582 - in reply to #620535)
What is the bulb number and I can try to do a search for it to see if they still make it.
Posted 2022-03-29 4:19 PM (#620583 - in reply to #620582)
resq302 - 2022-03-29 1:08 PM
If there was any info on the empty "LED HEADLIGHT" box (which I had in my hand 30 minutes ago), I would have searched it and found a good link for you already.
But there was nothing to search
The closest thing I have now is the info from BigBlockMopar's LED headlight install (link above), which is
"CSP H4 9003 HB2"
Searching that yields a range of options, including this one:
The search "CSP H4 9003 HB2": https://www.google.com/search?client=firefox-b-d&q=CSP+H4+9003+HB2
resq302
Posted 2022-03-29 6:27 PM (#620585 - in reply to #620535)
Ok. Thanks.
resq302
Posted 2022-03-29 6:41 PM (#620587 - in reply to #620535)
Looking at these bulbs.
https://www.amazon.com/INFITARY-Headlight-Headlamp-10000LM-Warranty/...
Posted 2022-03-29 7:37 PM (#620589 - in reply to #620587)
resq302 - 2022-03-29 3:41 PM
You might have missed that external ballast box that they sneak into the photo. Plus they are killer 6500 Kelvin. Way too white. Folks will hate you.
Price is okay but I don't think that they will work for a Forward Look car.
I wish I could find a link to the ones that I am running so you don't have to try re-inventing the wheel. The link that I provided above looks like the ones that I bought 4 year ago.
Not these:
Edited by 56D500boy 2022-03-29 7:42 PM
resq302
Posted 2022-03-29 9:54 PM (#620590 - in reply to #620535)
This one is closer to the one you mentioned but is still 6500 kelvin
https://www.amazon.com/AUXITO-Headlight-9000Lumens-Extremely-Convers...
Edited by resq302 2022-03-29 9:55 PM
resq302
Posted 2022-03-29 10:02 PM (#620591 - in reply to #620535)
Or this one. This is 6000k
https://www.amazon.com/LUOTONG-Headlight-Bulbs-Conversion-10000LM/dp...
Posted 2022-03-29 10:56 PM (#620593 - in reply to #620591)
resq302 - 2022-03-29 7:02 PM Or this one. This is 6000k
That one has a lot of "bootie". Might be too long to fit in the OE headlight bucket without some metal cutting.
resq302
Posted 2022-03-30 8:07 PM (#620606 - in reply to #620535)
Ah ha ! I might have found them !
https://www.amazon.ca/dp/B07DHMYXB3/ref=sspa_dk_detail_5?spLa=ZW5jcn...
Posted 2022-03-30 8:26 PM (#620608 - in reply to #620606)
resq302 - 2022-03-30 5:07 PM
Just make sure that you order the H4 version. Looks very much like the ones I (and BigBlockMopar) used.
Good luck.
resq302
Posted 2022-03-30 8:28 PM (#620609 - in reply to #620535)
ok. yeh, thats what I was thinking that they looked like yours and Bigblockmopar used. Hoping they are the same.
Thanks again for the help !
resq302
Posted 2022-03-30 8:36 PM (#620610 - in reply to #620535)
Appears that I was on Amazon CA (Canada). I just searched for the same thing in the USA on the regular Amazon web site and found it to be $6 cheaper. I should be getting them and the Hella H4 headlight housings both on Friday.
Mopar1
Posted 2022-04-01 2:55 PM (#620654 - in reply to #620610)
2000100025
resq302 - 2022-03-30 7:36 PM
but is it $6 cheaper (US vs Canadian $)?
dels56
Posted 2022-04-09 4:21 PM (#620803 - in reply to #620535)
1001001002525
Hi fellows, my wife and i have been away for the winter and i have not keep up on your postings. I did use The Hella housings and Aukee LED bulbs which i purchased on Amazon.ca. They are a plug and play which fit very nicely in the headlight bucket. I will try to find the info on these and add that to this thread later. The bulbs pictured above would not fit in the 56 headlight bucket.
Del S
Attachments DF12C7D4-65A6-4F24-9060-34C02AF55B21.jpeg (231KB - 120 downloads)
resq302
Posted 2022-04-09 9:21 PM (#620808 - in reply to #620535)
Thanks. I’m hoping to get these installed in the next couple of days.
dels56
Posted 2022-04-11 3:05 PM (#620846 - in reply to #620535)
1001001002525
We are back home and have access to my files.
I will try to attach some slides on my headlight LED conversion.
I did not do a page on aiming the headlights as this was done outside at night. Tis is how I did this part.
Backed the car off my hoist out side and measured a distance from the garage door to the face of the headlights. Then leveled it with block under wheels. I marked a center and horizontal lines on the door with masking tape and an ink marker. Then adjusted the lights to focus on these marks.
Del S
Edited by dels56 2022-04-11 3:24 PM
(IMG_7597 (3).JPG)
(IMG_7598 (3).JPG)
(IMG_7599 (3).JPG)
Attachments IMG_7597 (3).JPG (36KB - 114 downloads)
Attachments IMG_7598 (3).JPG (33KB - 105 downloads)
Attachments IMG_7599 (3).JPG (35KB - 107 downloads)
