Is there an after-market radiator for a 56 Coronet 315ci ?
Cormac
Posted 2022-02-24 4:45 PM (#619766)
Subject: Is there an after-market radiator for a 56 Coronet 315ci ?
I'd like to just be able to buy a replacement radiator from a web site that bolts right in.
Posted 2022-02-24 4:57 PM (#619767 - in reply to #619766)
Subject: RE: Is there an after-market radiator for a 56 Coronet 315ci ?
50005000100025
Cormac - 2022-02-24 1:45 PM
If your car was a 56 Chevy, the answer would obviously be "YES!!"
However, the market for 56 Dodge aftermarket parts just isn't there. So I think the answer is "No. "
I had mine re-cored. About the same cost as an aftermarket rad - if one existed. Only took a couple of days.
Good luck.
Edited by 56D500boy 2022-02-24 4:57 PM
bbdakota
Posted 2022-02-24 6:27 PM (#619769 - in reply to #619766)
Subject: Re: Is there an after-market radiator for a 56 Coronet 315ci ?
This one is pretty close. It's the one I used on my 56 royal Lancer 315 poly
Champion CC1635
Posted 2022-02-24 7:07 PM (#619770 - in reply to #619769)
50005000100025
bbdakota - 2022-02-24 3:27 PM
Champion CC1635
I thought that yours was a custom job.
https://www.championradiators.com/product/CC1635
bbdakota
Posted 2022-02-24 7:33 PM (#619772 - in reply to #619770)
56D500boy - 2022-02-24 6:07 PM
Champion CC1635
With the stock 4 blade fan,
I was able to bolt it in by only re-drilling a couple of the mounting holes. Thr bottom of the blades are close to the bottom tank. but I then modified the flange later so I could move the radiator fwd enough to use a derale 6 blade fan. I also made a shroud but the shroud was made to fit the fan/radiator setup.
