What is the correct gear oil to use?
1958fwdlk
Posted 2021-12-20 7:02 AM (#617786)
Subject: What is the correct gear oil to use?
In the 1958 Fury, what is the correct gear oil to use for the differential?
Experience (my mind is slipping a little) but 75-80 or 80-90 should be used correct?
Thank you for any help you can provide.
Happy Holidays to all
finsruskw
Posted 2021-12-20 8:24 AM (#617787 - in reply to #617786)
Subject: Re: What is the correct gear oil to use?
2000100100252525
Whatever the FSM dictates!
I've always used 80-90, the stinky stuff!
finsruskw
Posted 2021-12-20 8:24 AM (#617788 - in reply to #617786)
2000100100252525
1958fwdlk
Posted 2021-12-20 8:58 AM (#617789 - in reply to #617786)
Subject: RE: What is the correct gear oil to use?
Thank you!
Posted 2021-12-20 12:09 PM (#617792 - in reply to #617786)
20001000500100100252525
Depends on whether or not you have Sure-Grip, LS differentials require GL-5 oils while GL-4 will work for non-LS.
Personally, I use only GL-5 in everything (Synthetic 75W-90). The viscosity recommendations have changed over the years but the components haven't changed.
