Location: PL / EU | I am going to replace the upholstery in my '59 Fury, but I need the original dimensions. Any help is appreciated.
(2.jpg)
(3.jpg)
Attachments ---------------- 1.jpg (142KB - 95 downloads) 2.jpg (150KB - 98 downloads) 3.jpg (50KB - 92 downloads)
Location: So. Cal | Is it the same as the 2dr Sport Fury with the buckle emblems? If so, I could measure mine for you.
Edited by Powerflite 2021-07-11 11:11 AM
Location: PL / EU | I'm not sure. Swivel seat looks similar, but the center section of the rear bench looks wider on the SF.
But maybe it's just an illusion. Will the C line be in the center of the buckles in SF?
(01.JPG)
(02.JPG)
Attachments ---------------- 01.JPG (71KB - 94 downloads) 02.JPG (87KB - 93 downloads)
Location: So. Cal | I think the fronts will have the same dimensions, as you say, to the center of the buckles, which will correspond to the center of the buttons on yours. The rear, I'm not so sure of, as I see that the bottom is straight instead of angled like on the sport fury.
Edited by Powerflite 2021-07-11 1:06 PM
Location: PL / EU | Measuring your seats will be helpful.
I think the rear seat may differ like this:
(sf2.JPG)
Attachments ---------------- sf2.JPG (176KB - 91 downloads)
Location: So. Cal | Measuring from the fabric corners, not the buckles, it should be the same as yours. So I get:
C = 10"
B = 13"
D = 15"
But my seats are in worse shape than I thought so you would be better off getting a measurement from someone else. My front seats are too far gone to get the other measurements. The rear seat is significantly different so I don't think anything I measure there will be of help. |
