Replacing spark plug wire loom rubber/plastic
NC Adventurer
Posted 2021-04-22 12:56 PM (#611290)
Subject: Replacing spark plug wire loom rubber/plastic
Has anyone tried the plastic dip commonly used for tool handles to replace the rubber/plastic on the spark plug wire looms?
Posted 2021-04-22 1:11 PM (#611291 - in reply to #611290)
Subject: RE: Replacing spark plug wire loom rubber/plastic
20001000500100100252525
Yes, I've done it several times; works good.
b5rt
Posted 2021-04-22 4:59 PM (#611305 - in reply to #611290)
Subject: Re: Replacing spark plug wire loom rubber/plastic
Save a couple of old margarine dishes, easy to trim for a shallow dip.
Posted 2021-04-22 6:44 PM (#611307 - in reply to #611290)
500020002000500100100100100
NC Adventurer - 2021-04-22 9:56 AM
I am planning on restoring mine with stripping off the old rubber, cleaning and painting the metal semi-gloss black and then dipity-dooing them in black Plasti-Dip. Thanks for the margarine tub idea b5rt.
Edited by 56D500boy 2021-04-22 6:45 PM
dels56
Posted 2021-04-22 11:55 PM (#611313 - in reply to #611290)
1001001002525
Plasti Dip works great on many parts. Just follow the instructions. I transferred the Plasti Dip into a jar with a lid that seal tight. Still good after a year.
Del S
(IMG_6239 (3).JPG)
Attachments IMG_6239 (3).JPG (41KB - 156 downloads)
NC Adventurer
Posted 2021-04-23 8:10 AM (#611317 - in reply to #611313)
Thanks guys! I've never used the product and thought this would be a good place to get some feedback. The product itself is cheap enough and, as it seems to work well, appears to be the answer to taking things back to as lose as original as possible. The other option is to use aftermarket looms, which, in my opinion, look pretty nasty.
