horn repair or replacement for 56 plymouth/dodge ?
jerrybev
Posted 2021-04-01 5:32 PM (#610600)
Subject: horn repair or replacement for 56 plymouth/dodge ?
500100252525
hi
I have a 56 plymouth and hi horn does not blow. I took it to a mechanic and he could only get a weak sound occasionally. The parts of the horn are riveted together. What do most owners do with a mal functioning horn? Leads, referrals, suggestions appreciated on what I should do.
thank you
Jerry Whitfield
winston salem NC
Posted 2021-04-01 6:11 PM (#610603 - in reply to #610600)
Subject: RE: horn repair or replacement for 56 plymouth/dodge ?
500020002000500100100100100
Jerry: First off, you might find a horn on the internet. Here is a pair from a 56 Belvedere (but the high does work either):
http://www.2040-parts.com/1956-plymouth-dodge-12-volt-horns-i192090...
I had issues with mine on my 56 Dodge and I fixed it by buying a new horn and swapping in the internals into my horn's shell:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68724&...
jerrybev
Posted 2021-04-01 6:25 PM (#610604 - in reply to #610600)
500100252525
thank you
Jerry
samstrader
Posted 2021-04-06 2:53 AM (#610729 - in reply to #610600)
Subject: Re: horn repair or replacement for 56 plymouth/dodge ?
10010010010025
I bet Big M has some old horns that work.
