looking for an early AFB
normsclassicradio
Posted 2020-08-20 7:03 PM (#602339)
Subject: looking for an early AFB
I found a 4 bbl manifold for my 64 361. I would like to find the small neck AFB so my air cleaner will work. Any rebuildable core would do. Thanks!
Norm in Kalispell, MT
ABloch
Posted 2020-08-20 9:26 PM (#602348 - in reply to #602339)
Subject: Re: looking for an early AFB
1000100100100100252525
I can check in the morning for you Norm. Pretty sure I have a '65 core for you.
normsclassicradio
Posted 2020-08-20 11:46 PM (#602351 - in reply to #602339)
Someone emailed me and made me aware of 2 versions. There is a C body version were its push to open and a B body version works pull to open. Mine is the C body version where the linkage pushes it to open the throttle.
ABloch
Posted 2020-08-21 10:50 AM (#602356 - in reply to #602339)
Email sent. HO 4200S 1964 383 A/T
normsclassicradio
Posted 2020-08-21 5:12 PM (#602371 - in reply to #602339)
Subject: RE: looking for an early AFB
ABLOCH (Andrew) is THE MAN! He fixed me up with a carb he had on a 361 at one point. Great deal too! Thanks everyone who responded, I knew this was the right place to go!
normsclassicradio
Posted 2020-09-03 11:34 AM (#602888 - in reply to #602339)
Got the swap done last night. My buddy gave me a 383 intake , 2951866-2. 70-71 B-C body. The setup fit good, except I need a choke thermostat. OE number 2951653. If anyone has a used one I would appreciate it. Also, I found my car still had the original insulation under the intake. What do you folks do? Replace or leave it out? I left it out, as its oil soaked pretty bad.
Edited by normsclassicradio 2020-09-03 11:36 AM
(20200902_204857.jpg)
Attachments 20200902_204857.jpg (85KB - 164 downloads)
normsclassicradio
Posted 2020-09-03 4:48 PM (#602901 - in reply to #602339)
All hidden under the stock air cleaner housing..
(20200903_132711.jpg)
Attachments 20200903_132711.jpg (153KB - 169 downloads)
