4 barrel intake - low deck Dodge Poly or Hemi V8
jboymechanic
Posted 2020-08-17 3:01 PM (#602167)
Subject: 4 barrel intake - low deck Dodge Poly or Hemi V8
2000100252525
Just bought a 1956 Dodge 270 Poly V8 for my dad, he's looking for a 4 barrel intake manifold for it. Please let me know if you have anything.
Thanks.
Posted 2020-08-17 3:28 PM (#602170 - in reply to #602167)
Subject: Re: 4 barrel intake - low deck Dodge Poly or Hemi V8
500020002000500100252525
You can purchase new Offy aluminum for $488 from Hot Heads. http://hothemiheads.com/dodge/intake_manifolds/intake_1x4_241.270.h...
jboymechanic
Posted 2020-08-17 5:13 PM (#602178 - in reply to #602170)
2000100252525
I was aware of that Nathan and it may come to it, but seeing that the entire investment at this point is $200 we were hoping for a more economical solution.
Posted 2020-08-17 6:54 PM (#602188 - in reply to #602167)
Not likely. The stock 270 4bbl is a rare beast. Better buy an Offy while they are still available. But a low cost option would be to adapt a 4bbl to your stock 2bbl manifold. JB Weld Epoxy a 4bbl flange to the top of the intake and open up the holes for it. Bolt the flange to the intake as well, just to be certain it doesn't come loose. It would be better to braze it on, but you would need a custom flange made from steel to do that. Another low cost option is to use a 2bbl to 4bbl adapter, but the performance of those is questionable and they look stupid.
57DODGECONV
Posted 2020-08-18 7:48 PM (#602247 - in reply to #602167)
5001001001002525
Do you Have a Casting Number of the Intake you are Looking for?
jboymechanic
Posted 2020-08-22 1:20 AM (#602392 - in reply to #602167)
2000100252525
He might run a 500 cfm 2 barrel Holley on it, using the adapter. He already has the carb too, so that seems pretty likely
