56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Thought that if nobody has started a thread on this topic that I would. ![]() The first data point is in question: a 57 Coronet Lancer with red and black and ?? interior. Is it 213 or ?? frwl - 2020-08-16 6:02 AM. What the trim code is this? (White over black Coronet Lancer with red vinyl and black cloth) 213? LD3 Greg - 2020-08-16 9:02 AM The only reference I have for trim code 213 is Custom Coronet, red and gold? this is an incomplete note from Neil. Maybe he means red vinyl and black/gold cloth? Greg Tag in question (and then the car): Edited by 56D500boy 2020-08-16 12:47 PM (JohnSs57D500Coronet_interior.jpg) Attachments ---------------- ![]() | ||
LD3 Greg![]() |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | Possible winner here. It is a Custom Coronet and the piping is gold so the black cloth could well have the gold threads. Greg | ||
LD3 Greg![]() |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | Dave. This will be a huge leg up for you. Neil's chart. The top left 210,211,212 and 213 box is cut off but reads Cust Coro. (image.jpg) (image.jpg) Attachments ---------------- ![]() ![]() | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . In another, less appropriate thread, frwl said: frwl - 2020-08-16 11:02 AM . Thanks Greg. You probably right: Red Vinyl and Black Cloth with Gold Snoflakes/Stars on it John’s video shows red bolsters and black cloth on the Coronet Lancer… Looks like Coronet standard trim codes begins for 1xx, and Custom trim for 2xxx | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . In response to frwl's (Igor's) question about the 21? code on the cowl data tag on the black and white 57 Coronet D500, John S. replied arizona mopar gold - 2020-08-16 7:53 PM Correct...213 is the Red/ Black with gold snowflake cloth "Custom Coronet"...that is the original interior! First I've seen with the line embossed center sections...most I've seen is just plain smooth vinyl When I bought the car 2 years ago it still had the clear seat covers on it, but they were worn out discolored and spliting..I removed them carefully and saved them for templates to make new ones...Some state that the clear covers were installed at later dates...this is a 1 owner car parked up in 1966...the clear covers were installed with the Same 1 hog rings used to install the upholstery, not added later Here are some of John's seat photos taken when he first brought the car home: REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68509&... | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . So if I had to guess the Trim code for the 57 Custom Royal Lancer below (not restored so likely original cloth, etc), what number would it be? 215? REFERENCE: http://classiccardb.com/dodge/288384-1957-dodge-custom-royal-with-3... ![]() Edited by 56D500boy 2020-08-17 7:06 PM (1957-dodge-custom-royal-with-325-hemi-3.jpg) (1957-dodge-custom-royal-with-325-hemi_Interior.jpg) Attachments ---------------- ![]() ![]() | ||
LD3 Greg![]() |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | I would interpret his chart that 214-216 was for 4dr sedan, so my guess is 218. Greg | ||
frwl![]() |
Expert Posts: 2167 ![]() ![]() ![]() ![]() | . Correct me if I’m wrong: Coronet – Silver Strata (110, 111, 112, 113) Coronet Custom Trim – Star Dot (210, 211, 212, 213) Coronet Suburban and Sierra Wagons – Gotham Texture (230, 231, 232) – same as Custom Royal Wagons??? Royal Sedans – Sutters’ Gold (114, 115, 116) Royal Lancer Hardtops – Linear Lucidity (117, 118, 119) Custom Royal Sedans – Celestial (214, 215, 216) Custom Royal Lancer Hardtops – Staccato (217, 218, 219) Custom Royal Lancer Convertibles – Gotham Texture (220, 221, 222) Custom Royal Sierra Wagons – Gotham Texture (230, 231, 232) – same as Coronet Wagons??? (1957 Dodge Trim Examples.JPG) Attachments ---------------- ![]() | ||
frwl![]() |
Expert Posts: 2167 ![]() ![]() ![]() ![]() | . Dave: Are you sure that is a blue Custom Royal Trim you posted? I think that is a Royal Trim (probably Linear Lucidity), not a Custom Royal I posted for comparison below really ROYAL trim (but gray 117) and green CUSTOM ROYAL trim 219 (I guess Staccato) (1.jpg) (2 Royal Lancer Trim 117.JPG) (3 Royal Lancer Trim 117.JPG) (4 Custom Royal Lancer Trim 219.jpg) Attachments ---------------- ![]() ![]() ![]() ![]() | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | frwl - 2020-08-18 7:11 AM . Dave: Are you sure that is a blue Custom Royal Trim you posted? I was just going by what the seller called the car. But then again he says that the engine is a "326". Elsewhere, in another advert, he corrects the 326 to 325 but says "up for auction is a 1957 dodge royal custom with the super D500 325 hemi (just over 300 HP engine)". If anything it is a 325 D500 engine but not the dual 4 bbl Super D500. So he could be wrong about the "Custom" part too. No photos of the cowl tag to confirm/deny. The engine: ![]() ![]() Edited by 56D500boy 2020-08-18 11:40 AM | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . This 57 Sierra wagon looks like it has an all vinyl interior (maybe?): REFERENCE: https://www.hemmings.com/classifieds/dealer/dodge/sierra/2420118.htm... It's a Spectator = rear facing third seat and spare in the right fender cavity, accessed from outside: ![]() Edited by 56D500boy 2020-08-18 1:51 PM (57SierraWagonInterior_1.jpg) (57SierraWagonInterior_2.jpg) (57SierraWagonInterior_3.jpg) (57SierraWagonInterior_4.jpg) (57SierraWagonInterior_5.jpg) Attachments ---------------- ![]() ![]() ![]() ![]() ![]() | ||
frwl![]() |
Expert Posts: 2167 ![]() ![]() ![]() ![]() | . Great pictures, Dave! Thanks for sharing! What code of trim is that? Is it 110 or 210? Judging to VIN plate on the first picture (it starts for 35…) this car is a simply Sierra (Coronet line), not a Custom Sierra Cannot view all pictures in the link; my access to hemmings.com still denied… ![]() | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | frwl - 2020-08-18 12:21 PM Judging to VIN plate on the first picture (it starts for 35…) this car is a simply Sierra (Coronet line), not a Custom Sierra Based on this list and copy of the bill of sale with the 3853nnnn VIN , it is a Custom Sierra Edited by 56D500boy 2020-08-18 5:17 PM (57SierraWagonInterior_6.jpg) Attachments ---------------- ![]() | ||
frwl![]() |
Expert Posts: 2167 ![]() ![]() ![]() ![]() | . 1957 Dodge Trim Codes (anyway need to be confirmed) Coronet – all body styles 110 = Pellon Vinyl and Silver Strata Fabric – Gold and Black 111 = Pellon Vinyl and Silver Strata Fabric – Blue 112 = Pellon Vinyl and Silver Strata Fabric – Green Coronet – all body styles (Custom Trim) 210 = Pellon Vinyl and Star Dot Fabric – Gold and Black 211 = Pellon Vinyl and Star Dot Fabric – Blue 212 = Pellon Vinyl and Star Dot Fabric – Green 213 = Pellon Vinyl and Star Dot Fabric – Red and Black Royal Sedan 114 = Pellon Vinyl and Sutters’ Gold Fabric – Gold and Black 115 = Pellon Vinyl and Sutters’ Gold Fabric – Blue 116 = Pellon Vinyl and Sutters’ Gold Fabric – Green Royal Lancer Hardtops 117 = Pellon Vinyl and Linear Lucidity Fabric – Gold and Black 118 = Pellon Vinyl and Linear Lucidity Fabric – Blue 119 = Pellon Vinyl and Linear Lucidity Fabric – Green Custom Royal Sedan 214 = Pellon Vinyl and Celestial Fabric – Gold and Black 215 = Pellon Vinyl and Celestial Fabric – Blue 216 = Pellon Vinyl and Celestial Fabric – Green Custom Royal Lancer Hardtops 217 = Pellon Vinyl and Staccato Fabric – Gold and Black 218 = Pellon Vinyl and Staccato Fabric – Blue 219 = Pellon Vinyl and Staccato Fabric – Green 230 = Pellon Vinyl and Gotham Texture Fabric – Gold and Black 231 = Pellon Vinyl and Gotham Texture Fabric – Blue 232 = Pellon Vinyl and Gotham Texture Fabric – Green Custom Royal Lancer Convertible and Custom Sierra Station Wagons 220 = Pellon Vinyl and Gotham Texture Fabric – Gold and Black 221 = Pellon Vinyl and Gotham Texture Fabric – Blue 222 = Pellon Vinyl and Gotham Texture Fabric – Green Custom Sierra Wagons 230 = Pellon Vinyl and Gotham Texture Fabric – Gold and Black (in other case it is Red and Black) 231 = Pellon Vinyl and Gotham Texture Fabric – Blue (in other case it is Red and Black) 232 = Pellon Vinyl and Gotham Texture Fabric – Green (no examples) | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Good list Igor. Needs more confirmation. And an edit regarding "Pellon" (which isn't vinyl, it is the non-woven fabric): http://www.pellonprojects.com/about/about-us/history/ These ones that you posted in the 57 Dodge Body Code thread might or might not do that: 57 Sierra Wagon with a red Gotham 231 Trim code: 57 Sierra Wagon with blue or grey Gotham 220 Trim code: ![]() Edited by 56D500boy 2020-08-19 10:54 AM | ||
LD3 Greg![]() |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | I don't have an example of a Custom Coronet Convert. Does anyone? Do they even exist? Greg | ||
wheelcover![]() |
Veteran Posts: 156 ![]() ![]() ![]() Location: Wyoming | I’ve recently purchased a 1957 Coronet 2 door hardtop (Detroit built, VIN starts 3522...) and am hoping that I could get some help deciding the few option listed on the data tag. 292 324 485 Trim code 112 (which I see information about above and am trying to get cloth samples for) Paint 3LSS (which I believe is Heather Green on main body and Glacier White on roof/fin) Any help is appreciated. | ||
LD3 Greg![]() |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | wheelcover - 2020-08-24 1:45 AM I’ve recently purchased a 1957 Coronet 2 door hardtop (Detroit built, VIN starts 3522...) and am hoping that I could get some help deciding the few option listed on the data tag. 292 324 485 Trim code 112 (which I see information about above and am trying to get cloth samples for) Paint 3LSS (which I believe is Heather Green on main body and Glacier White on roof/fin) Any help is appreciated. Post an image of the body plate and I will do it. Greg | ||
wheelcover![]() |
Veteran Posts: 156 ![]() ![]() ![]() Location: Wyoming | Here you go, if I can get it to post my pic. Attachments ---------------- ![]() | ||
LD3 Greg![]() |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | wheelcover - 2020-08-25 2:43 AM Here you go, if I can get it to post my pic. Pic is fine. It is coded as follows: Coronet, V8, 2dr HT. schedule build date Mar. 5, two tone paint roof and fins glacier white, saddle and lower heather green. Transmission Powerflite ( sales code 322), heater defroster ( sales code 374 ), delivered by truck ( sales code 675 ). The trim code you know. The body plate only shows complete accessory groups, none here, but only the punch card will show all its individual options. By the condition of the body plate it looks like a nicely preserved car. Post some pics and maybe send for the punch card copy? Greg | ||
LD3 Greg![]() |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | I see I should have posted this in the decoding section that Dave highlighted! Greg | ||
wheelcover![]() |
Veteran Posts: 156 ![]() ![]() ![]() Location: Wyoming | Thank you for the information, but I don’t see where you are getting the codes you listed - it does have the Powerflite. I thought I understood something about this style data tag, but now I’m confused. | ||
LD3 Greg![]() |
Expert Posts: 1906 ![]() ![]() ![]() ![]() ![]() ![]() Location: Ontario, Canada | Sales codes do not show on 57 Dodge body plates but do on the broadcast sheet (if available) and the punch card. Greg | ||
moparwannabe![]() |
Regular Posts: 51 ![]() ![]() Location: Lödöse | Could anyone please help me decode this build sheet? | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | moparwannabe - 2022-12-06 11:36 AM Could anyone please help me decode this build sheet? Sure (maybe). It has to be less than 250 kB to be posted here. .jpgs will post better than .jpegs from Apple products but < 250 Kb is the key. ![]() | ||
moparwannabe![]() |
Regular Posts: 51 ![]() ![]() Location: Lödöse | Ill try to reduce it from 46mb ![]() | ||
moparwannabe![]() |
Regular Posts: 51 ![]() ![]() Location: Lödöse | Could not reduce it so much without "blurring" it to much. But it is on the 57-58 Dodge group on Facebook. https://www.facebook.com/photo/?fbid=10221832587663384&set=gm.836715... | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | Powerflite - 2022-12-06 12:46 PM Here you go. Please follow at the Fender/VIN tag sub-forum http://www.forwardlook.net/forums/forums/thread-view.asp?tid=78060&... ![]() | ||
frwl![]() |
Expert Posts: 2167 ![]() ![]() ![]() ![]() | 56D500boy - 2020-08-19 10:49 AM And an edit regarding "Pellon" (which isn't vinyl, it is the non-woven fabric): :) Better late than never... (1957 Dodge Trim Codes 1.jpg) (1957 Dodge Trim Codes 2.jpg) Attachments ---------------- ![]() ![]() | ||
56D500boy![]() |
Exner Expert 10K+ Posts: 10641 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . In another thread (57 Dodge Barn Find) here, frwl posted this page from the 57 Dodge Ross Roy data book: I couldn't find the source material yesterday but I did try again today and found it: https://www.hamtramck-historical.com/dealerships/1957DealershipDataB... Including this additional trim page: ![]() and frwl's page (except now bigger): ![]() Edited by 56D500boy 2025-02-06 5:55 PM | ||
