Location: Winston Salem, N.C. | 1955-1956 NOS dash gages: temp, oil pressure, NOS "Savoy" body script, $30 each. Used Powerflite trunk emblem $50, owners manual $10, gas door $10, free steering column. NOS master cyl. repair kit $10, NOS thermostat $10, Carb rebuild kit for Carter WCFG fits all Chrysler Corp cars 1955-1957, used: optional “Hollywood style steering wheel center with full horn ring $150, Used dash radio speaker plate $10, ash tray $10, outer gas door $10, cigarette lighter $5, temp gage dash knob $5, Have exterior stainless trim body spears, for 2 dr, 4 dr, and station wagon, inquire, $25; hood bird $35, headlight switch $15, 4 bbl Carter Carb WCFB 2202SA $70, dip stick tube, powerflite $10, carb choke $5, oil breather cap $5, generator fan double pulley cast iron $30, crank shaft damper pulley (2 grooves) for 8 cyl $12, water pump double pulley 8 cyl $12, generator $25, left rear bumper bracket for 55-56 car $15, single water pump pulley, clean $5, water pump rebuilt for V8 $20, water pump bypass hose with clamp $10, crankshaft pulley, single, clean, $20, seat tracks for front $10 pr, heater core no leaks $20, inside & outside heater blower box with motor $20, manual steering linkage $25, , cigarette lighter complete unit $25, hubcaps $35, radio $50
1955-1970: SBI 2 oil seals, $5, brake wheel cyl. repair kit NAPA # 291 & 212, $5 each, voltage regulator $20, Wagner wheel cyl. kit WK11345 $5, ignition resistor V8 # from A.L. Wells Co. #795 $5,Napa Rotor #AL125, $2, generator brushes Tungsten E46X $5, rotor button Borg Warner D-13 SHD $5, idler arm repair kit $20, distributor #1688647 $20, thermostat $10, Jerry Whitfield, Winston Salem, N.Carolina 336-749-5922 leave msg
thank you
Jerry
Edited by jerrybev 2020-06-15 7:12 PM
(56 ply hubcap.JPG)
(hrome script small.jpg)
(56 ply radio under.JPG)
(hollywood steering wheel 1956 plymouth xxxsmall.jpg)
(distributor.JPG)
(16 length oil dip stick small.JPG)
(1956 under hood.JPG)
(1956 front end.JPG)
Attachments ---------------- 56 ply hubcap.JPG (92KB - 191 downloads) hrome script small.jpg (96KB - 183 downloads) 56 ply radio under.JPG (76KB - 185 downloads) hollywood steering wheel 1956 plymouth xxxsmall.jpg (89KB - 195 downloads) distributor.JPG (175KB - 178 downloads) 16 length oil dip stick small.JPG (78KB - 177 downloads) 1956 under hood.JPG (101KB - 204 downloads) 1956 front end.JPG (188KB - 188 downloads)
