Having fun with long ram intake install Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
saratoga ny |
Regular Posts: 52 | Hey Guys !! Working on my 60 Saratoga and trying to piece together a Long Ram intake set up for it. I started out with just the rams air cleaners and cross over tube. The question of concern among many, is that my car (that was of coarse not equipped with long rams) is the large vacuum tank that originally was mounted on top of drivers front fender apron on my car, can not be mounted in that original location. Where did it mount on a car equipped with long rams? I am thinking behind the headlights inside of driver front fender? Also my original tank has only one nipple on the tank for the hose. Any feedback about this tank? Pics would help if possible. Thanks and I Hope Everyone is Well. | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | . I can't find a photo but I think that I have seen a photo of a long ram car with PB where the vacuum tank is still on the driver's side inner fender but it is turned 90 deg to normal, i.e. E-W instead of N-S. Seemed to fit between the left air-cleaner and the battery. That is what my memory says. It could be wrong. | ||
saratoga ny |
Regular Posts: 52 | Thanks, but still looking for more answers. | ||
geoffs60 |
Veteran Posts: 165 Location: christchurch New Zealand | The single vac pipe style tank has a plastic [fragile] Tee hose junction one way valve close to the booster, pretty sure this was 59 ?? but definately all 1960 on.With the vac tank down by the LF chassis rail inside the eng compartment by the rad support panel. Geoff | ||
Board Moderator & Exner Expert 10K+ Posts: 13054 Location: Southern Sweden - Sturkö island | The vacuum tank is mounted under the left front fender, just behind the headlight buckets on the 60 Chryslers | ||
b5rt |
Expert Posts: 2519 Location: central Illinois | On 60 DeSoto's the vacuum tank is mounted under the battery tray, on the LF fender apron and just barely visible under the tray. If you want a picture, PM me your email and I'll get it to you. | ||
Board Moderator & Exner Expert 10K+ Posts: 13054 Location: Southern Sweden - Sturkö island | b5rt - 2020-05-17 8:02 PM On 60 DeSoto's the vacuum tank is mounted under the battery tray, on the LF fender apron and just barely visible under the tray. If you want a picture, PM me your email and I'll get it to you. Same thing for the shorter 60 Windsor as well. | ||
NicksGarage |
Expert Posts: 1223 Location: Ramona, CA | Here's a picture from my '60 New Yorker, same mounting as in my 300F with the ram induction. (brake_vacuum_tank.jpg) (brake_vacuum_tank.jpg) Attachments ---------------- brake_vacuum_tank.jpg (154KB - 239 downloads) brake_vacuum_tank.jpg (147KB - 231 downloads) | ||
saratoga ny |
Regular Posts: 52 | Thanks to all for the info. All Stay Safe. | ||
