Auto Headlight Dimmer Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Mikeb |
Member Posts: 44 | Has anyone installed an Automatic Headlight Dimmer in a 59 Chrysler. If so, where do you mount the control box and is it necessary to modify any of the existing wiring harness? | ||
Fireflite56 |
Extreme Veteran Posts: 341 Location: Wisconsin | My '59 Fireflite control box is mounted on the driver's side behind the kick panel. I believe the wiring just plugs into the existing harness, no modification needed. It's in series with the floor-mounted dimmer switch and main harness. | ||
Fireflite56 |
Extreme Veteran Posts: 341 Location: Wisconsin | I snapped a couple photos today since I am (conveniently?) missing my kick panels. The box is mounted pretty high up, more behind the side of the dash. The wiring is behind where the kick panel should be. (IMG_20200416_185103839.jpg) (IMG_20200416_185032661.jpg) Attachments ---------------- IMG_20200416_185103839.jpg (112KB - 252 downloads) IMG_20200416_185032661.jpg (108KB - 235 downloads) | ||
Mikeb |
Member Posts: 44 | Thanks, the control box has a long and a short cable. Both have 3 wires, Black, red and green and both have female plugs. One for the floor dimmer and the other i believe would connect to the existing dimmer switch cable however they are both female. Are the 2 joined with some type of adapter cable? | ||
Mikeb |
Member Posts: 44 | Can anyone post a picture of the dash for the location of the scanner? Also, is the foot dimmer switch different for the auto system? | ||
Fireflite56 |
Extreme Veteran Posts: 341 Location: Wisconsin | If I think of it tomorrow, I can take a photo of my dimmer location (though my DeSoto may be different than a Chrysler) and take a closer look at the wiring. I believe the dimmer switch is the same between a standard system and the auto-dimming, but a check of the parts book would be good to confirm that. | ||
imopar380 |
Expert 5K+ Posts: 7207 Location: Victoria, BC, on Vancouver Island, Canada | 59 New Yorker with one (13.JPG) (19.JPG) (18.JPG) Attachments ---------------- 13.JPG (53KB - 231 downloads) 19.JPG (48KB - 230 downloads) 18.JPG (72KB - 226 downloads) | ||
Fireflite56 |
Extreme Veteran Posts: 341 Location: Wisconsin | Here are a few photos of my '59 Fireflite. My auto-dimmer is currently not working, so I have by-passed it until I get around to fixing it. If I recall correctly, that black plug shown is the pigtail on the dimmer switch going directly to the main harness, the same as a standard car. With the box correctly plugged in for the auto-dimmer, it would go in series between those two plugs. (IMG_20200426_203147193.jpg) (IMG_20200426_203157518.jpg) (IMG_20200426_203224989.jpg) Attachments ---------------- IMG_20200426_203147193.jpg (86KB - 244 downloads) IMG_20200426_203157518.jpg (84KB - 236 downloads) IMG_20200426_203224989.jpg (90KB - 252 downloads) | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Here another view, "cold coffee". - SERGE - Automatic Beam-Changer: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=23691&start=92 | ||
