1956 Plymouth custom subruban station wagon restored Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | now has a 1958 318", with added Power steering and power brakes and air conditioning. If anyone needs any parts, bet I can put them InTouch with someone who has them. jerrybev1@yahoo.com Jerry Whitfield Winston Salem NC (PD xxx small.jpg) (1956 plymouth xxxsmall xxx small.jpg) (IMG_1890 rear xxx small.jpg) (engine 56 plymouth.JPG) (frunt uph xxxsmall.jpg) (steering wheel xxx small.jpg) (door panel xxxsmall.jpg) Attachments ---------------- PD xxx small.jpg (124KB - 230 downloads) 1956 plymouth xxxsmall xxx small.jpg (184KB - 182 downloads) IMG_1890 rear xxx small.jpg (103KB - 185 downloads) engine 56 plymouth.JPG (123KB - 188 downloads) frunt uph xxxsmall.jpg (103KB - 202 downloads) steering wheel xxx small.jpg (119KB - 204 downloads) door panel xxxsmall.jpg (127KB - 206 downloads) | ||
GaryS |
Expert Posts: 1207 Location: Ponder, TX | Jerry, very nice! I like the way you've merged the old and the new and retained the appeal of the old. | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | . Looking good there, Jerry. Congrats. Question: Looks like the 58 318 came with a Torqueflite. Cast-iron? (I presume yes?) How did you handle the rear engine/transmission cross-member? Any photos? Glenn R. is trying to put a cast-iron TF in his 56 Plymouth and would appreciate more info including close-ups of the 5-button shifter plate, etc. Can't tell much from here except that it has 5 buttons. Edited by 56D500boy 2020-04-15 11:28 PM | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi please inform Glenn: I don't have the mechanical skill. I paid to have it done. He should call Jerry Mulcahey, Mocksville, N.C. 336-608-2954 and ask him to explain it to you. Best to call 9 am-3 pm EST. I'll let him know to expect a call. If he still needs photos, have him call me 336-749-5922 leave msg. Jerry Whitfield. In case anyone needs either a steering column or an automatic torque flite, each of those items are FREE. I have other parts including aluminum side trim from 2 door sedan, 4 door sedan, and station wagon | ||
Expert 5K+ Posts: 9681 Location: So. Cal | The shifter mechanism, plate, & pod that he used is from a '57 Plymouth. So he adapted that to work on the '56 Dash. | ||
Expert 5K+ Posts: 9911 Location: Lower Mainland BC | Powerflite - 2020-04-16 9:52 AM The shifter mechanism, plate, & pod that he used is from a '57 Plymouth. So he adapted that to work on the '56 Dash. Ah so. I see that now. 57 and 58 similar (or identical);) | ||
gradford |
Regular Posts: 87 | Your Suburban is a beauty, Jerry! and thank you, Dave, for asking Jerry about the Torqueflite adaptation. I can see that the newer mechanism and faceplate were adapted to the 56 shift pod. I have a similar idea in mind; I found a shift mechanism in a 58 Dodge that is a little narrower, and was planning to fabricate a faceplate that will fit in place of the existing Powerflite plate. But, the buttons look better from the 58 Plymouth, because they're closer to being the same shape as the 56's. My main concern was having to fabricate a new crossmember. Until Dave told me, I was unaware that the Torqueflite was a longer trans than the Powerflite. I'll crawl underneath and do some measuring and thinking once I get my 56 back from the bodyman. Jerry, how do you rate the Torqueflite for performance, vs the Powerflite in your Suburban? | ||
gradford |
Regular Posts: 87 | Hi Jerry I am looking for some trim pieces; I need the small (about 4") stainless trim pieces that attach to the rocker panel below the driver's door. Do you have any of those? Also, a power steering unit and column for a 56. (57/58 doesn't fit). Thanks Glenn | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi I can't give you an answer. When I bought the wagon it had no engine and I never drove it with the toorqueflite. jerry 336-749-5922 see my 56 wagon posted this wseek under "member rides" I have the torque flite emblem that goes on the rear. | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi wagon had no engine wwhen I bought it. I never drove it with torqueflite. Jerry 336-749-5922 I have the torque flite rear emblem | ||
gradford |
Regular Posts: 87 | Hi Jerry Can't stop looking at your Suburban... I did notice that you said you had some side trim from a 2 door sedan. If this is Savoy or Belvedere trim, could you send me some pictures? I'm looking for the stainless trim that goes on the rocker panel beneath the driver's door. Thanks! Glenn | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi Glenn: thank you for the compliments on my car. Can you communicate with me directly, in the future at jerrybev1@yahoo.com ? I don't come to this site regularly. I believe you refer to the small curved piece that wrap around the rocker panel and the one piece fastens underneath? Correct? thanks jerry | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | hi Glenn I have the steering column for 1956 and steering linkage, both for non power steering car. Jerry Whitfield Winston salem North Carolina direct email: jrrrybev1@yahoo.com | ||
jerrybev |
Elite Veteran Posts: 689 Location: Winston Salem, N.C. | CORRECTION: I misspelled my email. It is: jerrybev1@yahoo.com or 336-749-5922 thank yo Jerry Whitfield winston salem NC | ||
