56 Dodge Royal 4dr hardtop Jump to page : 1 2 3 Now viewing page 3 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9673 Location: So. Cal | Who did you order the springs from? | ||
Expert 5K+ Posts: 9907 Location: Lower Mainland BC | . I'm not Scott but I just re-read Page 2 of this thread and found I ordered new springs from coil spring specialties" Probably these guys: http://www.coilsprings.com/classic.aspx NOW I want to learn more about the exact specs that Scott gave them to work with. Sounds like the change was very successful. | ||
bbdakota |
Veteran Posts: 129 | 56D500boy - 2021-01-10 7:23 PM . I'm not Scott but I just re-read Page 2 of this thread and found I ordered new springs from coil spring specialties" Probably these guys: http://www.coilsprings.com/classic.aspx NOW I want to learn more about the exact specs that Scott gave them to work with. Sounds like the change was very successful. :) Yes! You are correct! Coil spring specialties. In my manual, there is direction on measuring ride height. Basically measure the inside pivot point of the lower control arm and compare to the outside pivot point. The manual says my inside pivot point should have been between 0" to 1" lower. So using 1/2" as a base point, it appeared my car was sitting 1-1/4" low and I liked the height so that's what I ordered. Coil spring specialties has the stock spring specs but also gathered information such as "does it have ac" to compensate for the extra weight. I informed them I was using vintage air and a aluminum radiator. Ordering heavy duty springs helped with handling especially since I got them a little lower than stock. | ||
samstrader |
Extreme Veteran Posts: 445 Location: Beaumont TX | sorry about your spring breaking. I'm glad to know where to get them if my springs break. BTW. I used your advice about using RTV on the rear main seal when I replaced it and the new seal is not leaking now. So thanks for all of your advice. Your care is really looking great... | ||
sermey |
Expert Posts: 1208 Location: SWITZERLAND | Be happy Scott, that Dave (56D500boy) has the similar car, has acquired a huge know-how in th last years on his 56 Dodge, and what is most important: no secrets - he shares all, a valuable source. Thanks Dave. - SERGE - Edited by sermey 2021-01-23 7:18 AM | ||
Expert 5K+ Posts: 9907 Location: Lower Mainland BC | sermey - 2021-01-23 4:11 AM Be happy Scott, that Dave (56D500boy) has the similar car, has acquired a huge know-how in the last years on his 56 Dodge, and what is most important: no secrets - he shares all, a valuable source. Thanks Dave. - SERGE Thanks for noticing Serge. I try (to help - by sharing). Sometimes, (or often), I am asking for help trying to figure things out. There will be one of those posts, later today. | ||
bbdakota |
Veteran Posts: 129 | samstrader - 2021-01-23 12:34 AM sorry about your spring breaking. I'm glad to know where to get them if my springs break. BTW. I used your advice about using RTV on the rear main seal when I replaced it and the new seal is not leaking now. So thanks for all of your advice. Your care is really looking great... Great samstrader! And thank you! | ||
bbdakota |
Veteran Posts: 129 | sermey - 2021-01-23 6:11 AM Be happy Scott, that Dave (56D500boy) has the similar car, has acquired a huge know-how in th last years on his 56 Dodge, and what is most important: no secrets - he shares all, a valuable source. Thanks Dave. - SERGE - Yes! Much appreciated 56D500boy. BTW SERGE, I've been watching the 3D emblem work you are doing. Looking good! Using Autocad and other 3D modeling software is my every day job so I have a good idea of the time you have invested. Thanks! | ||
bbdakota |
Veteran Posts: 129 | Well once the new springs settled in good, I'm thinking it's a little too low but still not decided. I did order 3/8" thick spring insulators to raise it a bit (should raise it 3/4") but not sure I'll install them. I came out of a parking lot last week and drug the mufflers. I either need to be more cautious or raise it up a little. Anyway, tonight, the wife and I talked our son into driving us around a while so we enjoyed some good oldies music and took in the sights. (20210124_091727_copy_1008x756.jpg) (20210124_174125_copy_1008x756.jpg) Attachments ---------------- 20210124_091727_copy_1008x756.jpg (239KB - 273 downloads) 20210124_174125_copy_1008x756.jpg (133KB - 279 downloads) | ||
bbdakota |
Veteran Posts: 129 | Update: the 56 dodge is been a blast! Everything is working great with the exception of the front brakes still are slow to release once the car is driven a while. It's a crazy problem. If at a complete stop, I stand on the brake pedal really hard, they will release correctly. The only thing I haven't replaced is the calipers. I might try replacing the calipers. I've checked the clearance on the master cylinder rod, replaced master cylinder, booster (the first booster did go bad), proportioning valve, installed a heat shield on the lines close to exhaust..... On a different project, here is a sneak peak at My 58 Plymouth I've been working on for way to long. Almost ready for paint and body. I'm a little reluctant to post much about it here because of the modern drivetrain, modern power rack and pinion/ Dakota front clip but that's what I wanted and much better than the manual steering, manual transmission, 4 wheel drum brakes the thing came with. It's a 5.7 hemi, NAG1 now. (20210515_134023_copy_1008x756.jpg) (20210508_193807_copy_1008x756.jpg) Attachments ---------------- 20210515_134023_copy_1008x756.jpg (343KB - 203 downloads) 20210508_193807_copy_1008x756.jpg (236KB - 206 downloads) | ||
Steve1956 |
Regular Posts: 81 | Hi Scott, I am restoring a 1956 Dodge Custom Royal 4 door sedan in Australia. I am currently getting the doglegs and wheel arches rust repaired. I need to trial fit for the fender skirts now that i want to fit, but I can't figure out how the brackets at the front of the fender skirts attach/ work. Would you have any photos, or can you take a photo for me. It seems like the rattler rod should go into the front bracket, and the rear rod just rest beside or on top of the rear bracket? I'm not sure how that front bracket mounts in the wheel arch ? Hope you can help.. See photo of front and rear brackets i have which I hope are correct. Thanks, Steve Edited by Steve1956 2021-12-07 1:51 AM (FS Brackets.jpg) Attachments ---------------- FS Brackets.jpg (308KB - 116 downloads) | ||
