1956 windsor break upgrade
Twotallkris34
Posted 2020-01-13 1:59 PM (#592867)
Subject: 1956 windsor break upgrade
Hello All,
I just inherited a 56 windsor the common complaint with this car is the breaks hanging up. I know everyone will say keep it orginal but I would like my wife and other family to drive it so I would like it safe. I was thinking of replacing all the break lines and upgrading to disc breaks in the front and putting a dual channeled master cylindar. I will keep the orginal drums in the back. This car has some old school power brake system in it. If any one can shed any light on this like disc kits that have worked well for them or masters that will fit the windsor it would be appreciated . Also or anyone can tell who manufactured the power break system that would be appreciated. ( I will add some pictures later)
Thanks
(WIndsor.jpg)
Attachments WIndsor.jpg (131KB - 213 downloads)
Posted 2020-01-13 2:43 PM (#592869 - in reply to #592867)
Subject: Re: 1956 windsor break upgrade
5000200020005001002525
Get the disc brake kit from AAJ. He may have 2 versions, one smaller for original wheels and one bigger for disc brake wheels. You can get your brake booster rebuilt by Booster Dewey. I like to use a remote dual master from a Mitsubishi truck with a remote reservoir, but a '67-'72 short top dual master also works.
ronbo97
Posted 2020-01-13 8:01 PM (#592885 - in reply to #592869)
2000200025
The power brake booster that you have was sold and made available by Chrysler dealerships as 'add on' power brakes. If your brakes keep 'hanging up', then you need to diagnose the problem. Likely culprits are old brake hoses or weak return springs. If you choose to go with a disk setup for the front, then AAJ or Scarebird are good choices. You will need to rebuild the rear brakes no matter what. If you've never worked with Chrysler brakes, there is a special puller needed to remove the drum/hub assembly. It's called a tapered axle puller. Google it or find one on ebay. It is the ONLY WAY to remove the rear drums.
Ron
Twotallkris34
Posted 2020-01-14 7:34 AM (#592907 - in reply to #592867)
Thanks Guys, I will check out those companies and no i have never worked on old Chrysler's before i will be sure to get that tool before i try to tear into the rear breaks Thank you !
