Forward Look NON-Technical Discussions -> Test Area | Message format |
frwl![]() |
Expert Posts: 2164 ![]() ![]() ![]() ![]() | . ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE | |||||||||||||||||||||||||||||||||||||||
frwl![]() |
Expert Posts: 2164 ![]() ![]() ![]() ![]() | . ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE | |||||||||||||||||||||||||||||||||||||||
frwl![]() |
Expert Posts: 2164 ![]() ![]() ![]() ![]() | ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE | |||||||||||||||||||||||||||||||||||||||
frwl![]() |
Expert Posts: 2164 ![]() ![]() ![]() ![]() | ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABC ABC ABC ABC ABC ABC ABC ABC ABC ABC ABCDE ABCDE ABCDE ABCDE ABCDE ABCDE ABC ABC ABCDE ABCDE ABC ABC ABCDE ABCDE | |||||||||||||||||||||||||||||||||||||||
frwl![]() |
Expert Posts: 2164 ![]() ![]() ![]() ![]() | 1955 - Manual Transmission Standard Not Available Not Available 1955 - Automatic Transmission Optional Standard Standard 1955 - Power Steering Optional Optional Optional 1955 - Power Brakes Optional Standard Standard 1956 - Manual Transmission Standard Not Available Optional 1956 - Automatic Transmission Optional Standard Standard 1956 - Power Steering Optional Optional Optional 1956 - Power Brakes Optional Standard Standard 1957 - Manual Transmission Standard Not Available Not Available Optional 1957 - Automatic Transmission Optional Standard Standard Standard 1957 - Power Steering Optional Standard Standard Optional 1957 - Power Brakes Optional Optional Optional Standard 1958 - Manual Transmission Standard Not Available Not Available Optional 1958 - Automatic Transmission Optional Standard Standard Standard 1958 - Power Steering Optional Standard Standard Standard 1958 - Power Brakes Optional Optional Optional Standard 1959 - Manual Transmission Standard Not Available Not Available Not Available 1959 - Automatic Transmission Optional Standard Standard Standard 1959 - Power Steering Optional Standard Standard Standard 1959 - Power Brakes Optional Standard Standard Standard | |||||||||||||||||||||||||||||||||||||||
56D500boy![]() |
Exner Expert 10K+ Posts: 10635 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | . Igor: The only way that I have found to do a "Table" in an html forum like the Forward Look is to put periods between each item so the spacing stays and doesn't collapse as it has above. This is a big pain in the butt. It is easier to keep the table in Excel and then do a screen shot of the table (using Shift Print Screen on your key board). Then I run that screen shot through Irfanview to trim away the unwanted bits. So either something like this (just a partial example): Build Date...Casting Date...VIN............D500 Number...Actual......Additional Info .................................................................................Number Dec 16, 1955.......................................1003...............3.............Hunter R's ...................01/26/56..........................1862...............862.........Phil W's (Painful) Or this (jpg from the screen shot of the Excel spreadsheet): ![]() Edited by 56D500boy 2020-01-12 12:48 PM | |||||||||||||||||||||||||||||||||||||||
frwl![]() |
Expert Posts: 2164 ![]() ![]() ![]() ![]() | 1955 - Manual Transmission .......Standard ...Not Available .....Not Available 1955 - Automatic Transmission ...Optional ....Standard ...........Standard 1955 - Power Steering ...............Optional ....Optional ............Optional 1955 - Power Brakes .................Optional ....Standard ...........Standard | |||||||||||||||||||||||||||||||||||||||
frwl![]() |
Expert Posts: 2164 ![]() ![]() ![]() ![]() | . Thanks for your explanation, Dave. I understand, but still cannot do screen shot of the Excel Table in jpg file… I can copy it just in the Word file using Shift Print Screen Well, it is not so important... it was a onetime event… ![]() | |||||||||||||||||||||||||||||||||||||||
56D500boy![]() |
Exner Expert 10K+ Posts: 10635 ![]() ![]() ![]() ![]() ![]() Location: Lower Mainland BC | frwl - 2020-01-14 6:33 AM . Thanks for your explanation, Dave. I understand, but still cannot do screen shot of the Excel Table in jpg file… Igor: You need to download (and use Irfanview). I use it daily (many times). This: (and download): https://www.irfanview.com/ 1. Shift Print Screen to capture what I want (whatever is on the screen that I need to use) 2. Open Irfanview (comes up with a black space) 3. EDIT 4. Paste (image appears in place of the black space) 5. Image 6. Resize/Resample 7. Select 1024/768 (good size for posting here) 8. OK 9. File 10. Save as (save the new image where you want it with the name that you want) 11. Do your forward look post and tick the [box] "Attach a file after posting" 12. Submit 13. Browse (and go to the folder with your new file) 14. Submit - the jpg will up load and show in a list on the right of the screen (repeat 13 and 14, as required) 15. Return to thread And there you have it. ![]() I just did that (with a bit of trimming while in Irfanview EDIT (right click and drag a box and then Crop Selection)) ![]() Edited by 56D500boy 2020-01-14 12:50 PM (IrfanviewHomePage.jpg) Attachments ---------------- ![]() | |||||||||||||||||||||||||||||||||||||||
Powerflite![]() |
Exner Expert 10K+ Posts: 10257 ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | This format is the official way to add tables onto the forum, but I haven't figured out why it adds such a large space before the table. Weird. Why the large space here?
(Table Format.jpg) Attachments ---------------- ![]() | |||||||||||||||||||||||||||||||||||||||
Powerflite![]() |
Exner Expert 10K+ Posts: 10257 ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | I figured out the cause of the large space. It seems to not like all the returns that I gave after each TR command. So it is bunching all those returns at the beginning of the table. Eliminate them, and it goes away. | |||||||||||||||||||||||||||||||||||||||
Powerflite![]() |
Exner Expert 10K+ Posts: 10257 ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | So here is a more pleasing version of the same thing.
(Better HTML Table.jpg) Attachments ---------------- ![]() | |||||||||||||||||||||||||||||||||||||||
Powerflite![]() |
Exner Expert 10K+ Posts: 10257 ![]() ![]() ![]() ![]() ![]() ![]() Location: So. Cal | Also, there are websites that will convert your table data to HTML so you don't have to type all that out each time. | |||||||||||||||||||||||||||||||||||||||
