Correct transmission fluid for a cast iron Torqueflite
Grady
Posted 2019-12-28 2:11 PM (#592131)
Subject: Correct transmission fluid for a cast iron Torqueflite
New User
What's the general consensus on the correct transmission fluid for a cast iron Torqueflite? I've had people tell me ever transmission fluid on the market. I know type A is what was originally used. The only type A still available seems to be the cheap golden star brand found at the gas station. Any experience with different types and brands appreciated.
local2Ed
Posted 2019-12-28 2:26 PM (#592132 - in reply to #592131)
Subject: Re: Correct transmission fluid for a cast iron Torqueflite
500252525
I use DexIII/Mercon which I'm pretty sure was recommended on this forum.
Posted 2019-12-28 3:49 PM (#592138 - in reply to #592131)
Subject: RE: Correct transmission fluid for a cast iron Torqueflite
20001000500100100252525
Welcome to the board.
There is no agreement on what is "correct", some favor the Dexron/Mercon and others favor Type F. Either will work.
Grady
Posted 2019-12-28 7:44 PM (#592151 - in reply to #592131)
New User
Thanks for the replies everyone.
Posted 2019-12-29 2:23 AM (#592165 - in reply to #592131)
5000
really need to search on this one its been discussed alot Can't remember what I bought but its synthetic... way dextron 3 or 4 or 5... cant remember, original stuff was swill
Posted 2019-12-29 1:01 PM (#592186 - in reply to #592165)
The original spec Type A fluid contained sperm whale oil because of its exceptional lubricity and heat stability. Sperm oil was outlawed in the early seventies so its use ended.
Calling Type A "swill" isn't very informed.
