1958 Firesweep Data Plate Help Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
59 explorer |
Extreme Veteran Posts: 384 Location: Hershey PA | I am trying to help translate a 1958 Desoto data plate 0604 car scheduled June 4, 1958 413 Desoto Firesweep 4 door sedan AAA Black top/body/sweep 999 Special interior 292 ? 305 ? 312 ? 512? | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | . Don't think this will help but it might (Sorry it is all the Desoto info that I have): 1960 Adventurer Broadcast Sheet: Edited by 56D500boy 2019-10-25 9:04 PM (1960AdventurerBroadcastSheet_Large.jpg) Attachments ---------------- 1960AdventurerBroadcastSheet_Large.jpg (233KB - 254 downloads) | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | 59 explorer - 2019-10-25 8:35 PM I am trying to help translate a 1958 Desoto data plate 0604 car scheduled June 4, 1958 413 Desoto Firesweep 4 door sedan AAA Black top/body/sweep 999 Special interior 292 ? 305 ? 312 ? 512? Can you show me the actual body plate? Is this a wagon? Greg | ||
frwl |
Expert Posts: 1892 | 292 = Powerflite 2speed Automatic Transmission 305 = Power Tail Gate Window (body styles should be 471 = Firesweep Shopper, 6P and 472 = Firesweep Explorer, 9P) 312 = Accessory Group No. 2 that includes: Glove Box Map Light Ash Tray Light Trunk Light Hand Brake Warning Light Vanity Mirror Prismatic Mirror Outside Mirror Left License Plate Frame Heater Windshield Washer Variable Speed Windshield Wipers Special Steering Wheel Radio less Electro Touch Tuner Electric Clock 511 = Wheel Covers, 512 = no info. Maybe Deluxe Wheel Covers | ||
frwl |
Expert Posts: 1892 | To 1960 DeSoto Broadcast Sheet… Schedule Date 0211 = February 11, 1960 Body Type 722 = Adventurer 2door Hardtop Trim 806 = Black Cloth and Red Vinyl Paint WB2 = Shell White Roof Color and Black Body Color 305 = Basic Group No. 1: Heater Radio Power Steering Power Brakes Dual Jet Windshield Washer Parking Brake Light Electric Clock 3way Prismatic Mirror Vanity Mirror License Plate Frame Left Outside Rear View Mirror 323 = Dual Manual Antennas 377 = Autopilot Cruise Control 441 = Solex Glass – All Window Areas 521 = 2.93 to 1 Rear Axle Ratio 534 = 35 Amperes Generator 554 & 562 = 42 = 8.00 x 14 White Side Wall Rayon Tires 588 = Undercoating and Under Hood Pad 622 = Transportation Carrier 635 = Transportation Route 7203116003: 7 = DeSoto, 2 = Adventurer, 0 = 1960 Model Year, 3 = Jefferson Avenue Assembly Plant, Detroit Michigan (Trim 806-1.jpg) (Trim 806-2.jpg) Attachments ---------------- Trim 806-1.jpg (126KB - 254 downloads) Trim 806-2.jpg (101KB - 256 downloads) | ||
Fireflite56 |
Extreme Veteran Posts: 341 Location: Wisconsin | Greg, this is the actual body tag from the original post by Bob for the '58 Firesweep in question. (1958 Data Plate_A.jpg) Attachments ---------------- 1958 Data Plate_A.jpg (221KB - 253 downloads) | ||
Lancer Mike |
Location: The Mile High City | I wonder if that decode is the same for the Detroit-built 1958 Dodge? If so, Powerflite 2 speed automatic Heater / Defroster Power brakes Car service (vehicle prep) Dealer's own truck for delivery
Build on or around June 7, 1958 De Soto, Firesweep, Sedan Monotone Black Interior Trim Code 999? 999 is typical code for custom or special order.
Warning: this could all be totally wrong!
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Fireflite56 - 2019-10-29 4:47 PM Greg, this is the actual body tag from the original post by Bob for the '58 Firesweep in question. Mike is correct. It is coded as a sold car and the BDY code is Firesweep 4 Dr. Sedan. Is it a 6 Cyl car? The 3 in 413 would be 6Cyl if it was a Dodge. Greg | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Lancer Mike - 2019-10-29 7:05 PM I wonder if that decode is the same for the Detroit-built 1958 Dodge? If so, Powerflite 2 speed automatic Heater / Defroster Power brakes Car service (vehicle prep) Dealer's own truck for delivery
Not wrong at all! Well done. Greg | ||
59 explorer |
Extreme Veteran Posts: 384 Location: Hershey PA | What does 607 signify? | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | 59 explorer - 2019-10-30 11:34 AM What does 607 signify? 607 is meaningless. It is not a code. That is why I needed to see the actual body plate. The 7 in that position is what is significant, stands for code 637 which is "route" which in this case means delivered by the dealers truck. Is the car 6 or 8 cylinder? Greg | ||
Lancer Mike |
Location: The Mile High City | Thanks Greg. It was a lucky guess. I knew that the 1958 De Soto Firesweeps rolled off the same assembly line as the 1958 Dodge. The plate looks so similar, I thought it may have the same codes.
I don't think De Soto offered a six cylinder car in 1958 as Dodge did? I thought the base engine for Firesweeps was a 350?
However, I know De Soto built fleet vehicles...perhaps they could be had with the six? Edited by Lancer Mike 2019-10-31 11:03 PM | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Lancer Mike - 2019-10-31 10:49 PM Thanks Greg. It was a lucky guess. I knew that the 1958 De Soto Firesweeps rolled off the same assembly line as the 1958 Dodge. The plate looks so similar, I thought it may have the same codes.
However, I know De Soto built fleet vehicles...perhaps they could be had with the six? Lucky is good but the truth is that you spotted the similarity before I did! Good work, and thanks!! While I don't pretend to know anything about Desotos, when I was looking for front end pot metal donors for my Regal, I noticed that Firesweep body plates were the same as Dodge. So, I took pics and documented a few of these carss. My findings seemed to agree with Neil's so no further action was taken. A few years ago I put out several requests for Firesweep owners to submit their body plate images. NO INPUT AT ALL. Greg | ||
Chrycoman |
Expert Posts: 1819 Location: Vancouver, BC | DeSoto did offer a six cylinder model Firesweep in 1957 and 1958 - mainly for taxis. The 1957 Firesweep Six went into production in January, 1957, which is why the engine number prefix was changed. The 1957 Dodge Coronet 230.-6 cid six cylinder engine serial numbers had prefix D72 and in January it was changed to KDS : K - 1957 / D - Dodge / S - DeSoto. Total production of DeSoto S27 Firesweep Six 4 door sedans came to 139 units. No idea how many were built for 1958, but I suspect it was a little lower than 139. | ||
Lancer Mike |
Location: The Mile High City | If this car has the Getaway Six (at least that's what Dodge called it), that may go a long way to explaining the 999 trim code. | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | We have tried to answer their questions so why won't Bob and David simply tell us what engine is in the car!! Greg | ||
59 explorer |
Extreme Veteran Posts: 384 Location: Hershey PA | The data plate is from the black 58 ambulance seen recently on the interne The owner has confirmed the car has the 350 V-8 and is checking the other code items like Powerflite etc | ||
59 explorer |
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | 59 explorer - 2019-11-02 4:35 PM The data plate is from the black 58 ambulance seen recently on the interne The owner has confirmed the car has the 350 V-8 and is checking the other code items like Powerflite etc Interesting! Thank,you. Greg | ||
Lancer Mike |
Location: The Mile High City | Interesting! I guess the Memphibian group made that out of a sedan. That data tag makes sense. (05 reduced.jpg) Attachments ---------------- 05 reduced.jpg (244KB - 251 downloads) | ||
LD3 Greg |
Expert Posts: 1906 Location: Ontario, Canada | Lancer Mike - 2019-11-02 8:56 PM Interesting! I guess the Memphibian group made that out of a sedan. That data tag makes sense. Mike. Thanks for the photo! Thanks for starting this thread, Bob. Fun project!! It was coded as a sold car so I wonder who actually ordered it. The conversion company? If so, easy to understand the 999, special order interior. Seems odd to me they would order a sedan rather than a wagon. The owner should get the punch card. Greg | ||
