Need an oil bath air cleaner for a 1958 Plymouth 318". Leads, referrals, appreciated.
You may reply here or call 336-749-5922 and leave message and I'll return your call.
thank you
Jerry Whitfield
Winston salem, NC
to see pictures of a 1958 oil bath air cleaner for 58 Plymouth 318" go to:
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=66938 |
Location: So. Cal | Those aren't oil bath. They use air filters. The last oil bath was used in 1956. Starting in '57, everything used an air filter. |
If you need the correct paper element air cleaner for a '58, I have them available in good condition. These would be for the 2-barrel carburetor.
---John |
Location: Lower Mainland BC | Powerflite - 2019-10-25 11:25 AM
And 57-58 Plymouth's didn't necessarily use the side-saddle air cleaner like the 57 Dodges.
(57PlymouthAirCleaner.jpg)
Attachments ---------------- 57PlymouthAirCleaner.jpg (122KB - 136 downloads)
Location: So. Cal | I don't think they ever did, except maybe some Canadian or export Plodge combo.
What did a '57 Plymouth 4bbl air cleaner look like? Does it look the same as the '58 4bbl air cleaner - similar to the 2bbl, but bigger? |
Location: Lower Mainland BC | Powerflite - 2019-10-25 3:32 PM
The photo above that I posted was of a 57 Plymouth (but I don't know 2 or 4 bbl).
Here is another "opinion":
Edited by 56D500boy 2019-10-25 6:40 PM
