Cast Iron Torqueflites - Front Pump Rotor thicknesses
Posted 2019-10-15 9:47 PM (#588876)
Subject: Cast Iron Torqueflites - Front Pump Rotor thicknesses
500020002000500100100100100
I just retrieved the front pump for my 57 Windsor cast iron TF from the transmission shop to help with the search for new parts (separate thread).
I was surprised that inner and outer rotors were both about 0.68" thick. I thought that they would be thinner. I have no clue what the thickness of the "high flow" 58-61 1736162 inner and 1736163 outer rotor/gear set was/is.
Anybody know?
Mine:
Outer:
Inner:
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=72383
Shep
Posted 2019-10-15 10:23 PM (#588879 - in reply to #588876)
Subject: Re: Cast Iron Torqueflites - Front Pump Rotor thicknesses
20001000100100100252525
Remember, what ever the gear thickness was, the pump body would be different to accommodate that diffent thickness if in fact it there were different thickness gears.
Posted 2019-10-15 11:22 PM (#588880 - in reply to #588879)
Shep - 2019-10-15 7:23 PM
Remember, what ever the gear thickness was, the pump body would be different to accommodate that different thickness if in fact it there were different thickness gears.
Thanks. I know that. (I think )
The original PN for the 56-57 pump housing assembly with the two rotors (1636 394 inner and 1633 658 outer) was 1879 394. Apparently that eventually superceded to the 2084 319 assembly (with the 58-61 gear/rotor set, 1736 162 inner and 1736 163 outer) (image of said NOS assembly below). Have no idea how thick the 17 series rotors are.
What I am trying to determine is do I have the original "low flow" pump body and gears/rotors or do I have the "high flow" pump and rotors (?)
Edited by 56D500boy 2019-10-15 11:24 PM
Posted 2019-10-25 1:38 PM (#589237 - in reply to #588876)
Subject: RE: Cast Iron Torqueflites - Front Pump Rotor thicknesses
56D500boy - 2019-10-15 6:47 PM.
I just retrieved the front pump for my 57 Windsor cast iron TF from the transmission shop to help with the search for new parts (separate thread). I was surprised that inner and outer rotors were both about 0.68" thick. I thought that they would be thinner. I have no clue what the thickness of the "high flow" 58-61 1736162 inner and 1736163 outer rotor/gear set was/is.
Anybody know?
Found out by buying a 1949 600 (superceded PN for the 1736 162 inner). About 0.81 inches:
REFERENCE: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=72383&...
