Factory Instructions for Adjusting a 12V "Jubilee" Horn.
Posted 2019-09-17 7:05 PM (#587674)
Subject: Factory Instructions for Adjusting a 12V "Jubilee" Horn.
500020002000500100100100100
I just picked up a NOS 12V Jubilee horn that I am going to cannibalize to fix my 56 Dodge LO-JUB horn, as discussed in this thread (thank Nathan for the head's up BTW):
http://www.forwardlook.net/forums/forums/thread-view.asp?tid=68724&...
Interestingly (to me), the eBay NOS horn (which BTW is the same diameter as my OE horn so parts swapping *should* work) came with adjustment instructions. Basically there are no adjustments. You're not supposed to play with the big adjustment screw and nut that were adjusted at the Jubilee (TM brand) factory but you can adjust the little screw as the points wear with time. OKAY. That might explain my issue with my original horn. It might be so far out of adjustment that it's FKd.
Here is the new horn, soon to be sacrificed for its parts and the instructions:
(eBayJubileeLO_1.jpg)
(eBayJubileeLO_2.jpg)
(eBayJubileeLO_3.jpg)
(JubileeHornInstalltionAndAdjustmentInstructions_Small.jpg)
Attachments eBayJubileeLO_1.jpg (221KB - 258 downloads)
Attachments eBayJubileeLO_2.jpg (241KB - 249 downloads)
Attachments eBayJubileeLO_3.jpg (247KB - 261 downloads)
Attachments JubileeHornInstalltionAndAdjustmentInstructions_Small.jpg (171KB - 256 downloads)
