Adding a pin to a Script Dodge Logo - a job for Muggy Weld?? Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Expert 5K+ Posts: 9905 Location: Lower Mainland BC | . Previously I have attempted to fix a 55/56 Plymouth horn ring with Muggy Weld. It worked(ish) but the US Postal Service tested the weld and it was found wanting. After my second (or third) try "not bad" : After the USPS go through with it : This thread: http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69374&... I recently found a very nice 55/56 Dodge Script Logo on eBay with very little if any pitting so I snapped it up. Not sure if I noticed one of the pins on the back was missing/broken. Regardless, the quality of the rest of the logo was good enough to ignore that issue and hope that I can fix it. Seeing that I still have the Muggy Weld stuff, I am going to try to fix the broken pin. I see that the pin was hollow so there is a chance to use the hole to reinforce the addition of a new pin. (On the back of the "e" in Dodge): Open to suggestions (as usual) This is what I have to work with: Edited by 56D500boy 2019-09-14 7:23 PM (eBayDodgeScriptLogo_Front.jpg) (eBayDodgeScriptLogo_Back.jpg) Attachments ---------------- eBayDodgeScriptLogo_Front.jpg (210KB - 86 downloads) eBayDodgeScriptLogo_Back.jpg (190KB - 94 downloads) | ||
Expert 5K+ Posts: 9905 Location: Lower Mainland BC | Not wanting to start a new project (converting a NOS "Model A" Jubilee horn into a 56 Dodge Jubilee horn), I decided to go back to the Dodge Script issue (broken stud/pin) to see if I could make some progress there. That I did. First thing was I checked the size of the stud against yhr 8-32 and 6-32 machine screws which I have on hand and decided that the closest size was the 6-32. Then I decided to see if I could drill out the machine screw so I could use a guide pin to hrlp connect/align the machine screw with the broken stud/pin on the script logo. I put the 6-32 machine screw in a vise with the flat end up and I started drilling with a 3/64 drill bit. I was lucky enough to get the bit started close (enough) to the centre of the end of the machine screw. I went slow and was able to get in about 3/16" in without breaking the bit (almost a first). Then I switched to a 1/16" bit and went in a total of about 5/16". Went surprisingly well. Then I used the same 1/16" bit and drilled into the broken stud using the existing hole in the stud as the starting point. Went in about 3/16 or so. Then I used my Dremel to create a flat square top for the machine screw to land on. I couldn't find a small brad nail so I sacrificed the 1/16" bit and cut a guide pin about 3/8" long with my Dremel. Might need to be a bit longer. I trialed the guide pin in the script logo stud and the 6-32 machine screw. Looks like it will work well enough. If I didn't have the Muggy Weld, I think I would try epoxy or regular solder. However, I do have the Muggy Weld so that will be the next step. Maybe tomorrow. Photos from this afternoon (took about 30 minutes total): Edited by 56D500boy 2019-09-18 1:21 AM (DrillingOutA6_32MachineScrew_showingGuidePin.jpg) (DrillingOutA6_32MachineScrew_WithGuidePinInserted.jpg) (DrillingOutTheBrokenPin.jpg) (DrillingOutTheBrokenPin_AddingAGuidePin.jpg) (InsertingDrilled6_32MachineScrewOverGuidePinInBrokenStud.jpg) (InsertingDrilled6_32MachineScrewOverGuidePinInBrokenStud_FullInsertion.jpg) Attachments ---------------- DrillingOutA6_32MachineScrew_showingGuidePin.jpg (49KB - 84 downloads) DrillingOutA6_32MachineScrew_WithGuidePinInserted.jpg (53KB - 101 downloads) DrillingOutTheBrokenPin.jpg (64KB - 83 downloads) DrillingOutTheBrokenPin_AddingAGuidePin.jpg (64KB - 89 downloads) InsertingDrilled6_32MachineScrewOverGuidePinInBrokenStud.jpg (69KB - 92 downloads) InsertingDrilled6_32MachineScrewOverGuidePinInBrokenStud_FullInsertion.jpg (72KB - 106 downloads) | ||
Expert 5K+ Posts: 5006 | good stuff, its hard to do real precise work with the mugglyweld. I kind of blast it on and it takes a ton of time taking it down slowly. just rip the pins off fill up the back with muggyweld or some other filler, and 3m double sided tape it on | ||
Expert 5K+ Posts: 9905 Location: Lower Mainland BC | Okay. Today was yesterday's tomorrow and while I was waiting for door sill paint to dry, I set up the Script Logo, the 6-32 machine screw and the internal pin made from a 1/16" drill bit. I put the script in the vice (Black and Decker Workmate) and adjust the height so the 6-32 machine screw rested nice and square on an angle bracket that I had in the workshop. Then I put Muggy Weld flux on the joint and up the wazzoo where the sun don't shine. Then I fired up my wife's kitchen torch and heated the fluxed area until the flux was brown and bubbling. Then I applied the Muggy Weld rod. Went reasonable well (or so I thought). As I was trimming off the excess "weld" (really a type of solder), I noticed that the heat had bubbled the chrome on the pot metal (WTH!!??) Oh my. I used my Dremel for the initial trimming and then a metal file. I supported the joint well but even doing that, it broke at the joint. Oh my. So after a few minutes of cursing, I got the machine screw and script back together for another try. This time I made sure that there was flux up the script pin's hole. Then I taped it back in place on the Workmate and tried again. This time I wasn't worried about being pretty. (In fact the result was ugg-a-lee). When things cooled, I trimmed the excess off with the Dremel. I did not use the file this time. When I was happy(ish), I cut the 6-32 machine screw to about the same total length as the OE pins on the script logo. I had thought that I would use a 6-32 die on the end result but I'm not confident that the "weld" will hold enough to withstand the torque of the die as it is turned down over the 6-32 threads and then into the Muggy Weld. A bit depressing to be honest. I bought the script because the chrome was nice, no pits. Now it has some bubbles. Oh my. Photos: (SettingUPToUseTheMuggyWeld_1.jpg) (SettingUPToUseTheMuggyWeld_2.jpg) (AfterTheFirstGoWithMuggyWeld.jpg) (AfterTheSecondGoWithMuggyWeld.jpg) (AfterTheSecondGoWithMuggyWeld_AfterTrimmingWithDremel_1.jpg) (AfterTheSecondGoWithMuggyWeld_AfterTrimmingWithDremel_2.jpg) Attachments ---------------- SettingUPToUseTheMuggyWeld_1.jpg (135KB - 96 downloads) SettingUPToUseTheMuggyWeld_2.jpg (128KB - 89 downloads) AfterTheFirstGoWithMuggyWeld.jpg (123KB - 106 downloads) AfterTheSecondGoWithMuggyWeld.jpg (149KB - 110 downloads) AfterTheSecondGoWithMuggyWeld_AfterTrimmingWithDremel_1.jpg (114KB - 84 downloads) AfterTheSecondGoWithMuggyWeld_AfterTrimmingWithDremel_2.jpg (122KB - 86 downloads) | ||
