Detroit built 57 Dodge D500s in my registry.
   Forward Look Technical Discussions -> Fender/VIN Tag and Broadcast Sheet DecodingMessage format
LD3 Greg
Posted 2019-08-05 11:11 PM (#585677)
Subject: Detroit built 57 Dodge D500s in my registry.
Note:
All this info was taken from body plates and verified by inspection and/or photos of the cars. The info as available was recorded in this order.
VIN, Body style, model code, schedule build date, engine number, engine casting date, comments.
1. No vin, CR 2 DrHT, 2586, 0222, KD500-11515. Original Super D? Car was junked.
2. No vin, Coro convert, 2543, 0328, KD500-------
3. 35269348, Coro 2DrHT, 2546, 0619, KD500-16593, 05-15-57. Original Super D? Now "restored" as a CR!
4. 37262976, CR 2DrHT, 2586, 1217, KD500------.
5. 37270337, CR convert, 2583, 1211, KD500-------.
6. 37272631, CR 2DrHT, 2686, 0117, KD500------
7. 37289020, Coro 2DrHT, 2526? , 0315, engine?
8. 37291130, CR 2DrHT, 2586, 0329, KD500-11823, Was Neils car.
9. 37294932, Royal 2DrHT, 2576, 0411, KD500-12662, 04-05-57
10. 37296112, CR 4DrHT, 2589, 0301, KD500-12809
11. 37301134, CR convert, 2583, 0425, KD500--------
12. 37311199, CR 2DrHT, 2586, 0620, KD500-16941
13. 37314968, CR 4DrHT, 2589, 0711, KD500----
14. 37321286, CR 2DrHT, 2586, 0903, KD500-19478, 08-22-57. Only 328 Dodges built after this one!
Anyone please add to this.
Greg
Posted 2019-08-06 2:05 AM (#585684 - in reply to #585677)
Subject: RE: Detroit built 57 Dodge D500s in my registry.
500020002000500100100100100
LD3 Greg - 2019-08-05 8:11 PM
Note:
Here's what I have collected over almost 3 years on this forum (Some with better documentation, some with none)
Edited by 56D500boy 2019-08-06 2:13 AM
(KD500_12275_April3_1957.jpg)
(KD500_12809.jpg)
(KD500-12944.jpg)
(57DodgeD500SierraWagonBodyPlate_Complete_GoesWithEngineKD500_12944.jpg)
(KD500-14549_May7_1957_small.jpg)
(KD500-18712.jpg)
(KD500-19201.jpg)
Attachments KD500_12275_April3_1957.jpg (149KB - 402 downloads)
Attachments KD500_12809.jpg (237KB - 397 downloads)
Attachments KD500-12944.jpg (129KB - 389 downloads)
Attachments 57DodgeD500SierraWagonBodyPlate_Complete_GoesWithEngineKD500_12944.jpg (132KB - 412 downloads)
Attachments KD500-14549_May7_1957_small.jpg (224KB - 371 downloads)
Attachments KD500-18712.jpg (76KB - 411 downloads)
Attachments KD500-19201.jpg (75KB - 385 downloads)
Posted 2019-08-06 10:44 AM (#585706 - in reply to #585677)
Subject: Re: Detroit built 57 Dodge D500s in my registry.
1000500100100100252525
Hello LD3 Greg
This is mine idetifications
Coronet
Series D72 / D66 / D70. Wheelbase 122 inches. Built 185194 units.
2042
2045 2door Sedan
4door Sedan 3400lbs
3470lbs $2162
$2237 7175
10483 230CID L6 1BBL,
Bore/Stroke 3,25/4,63 inches,
Compression Ratio 8,00 to 1,
138HP/4000RPM,
208LBS.FT/1600RPM.
Posted 2019-08-06 10:45 AM (#585707 - in reply to #585677)
Excuse me, this is wrong, just a second
Posted 2019-08-06 11:03 AM (#585709 - in reply to #585677)
Hello LD3 Greg
This is mine identifications:
Coronet
2042 = 2door Sedan = 3400 Lbs = $2162 = 7175 built
2045 = 4door Sedan = 3470 Lbs = $2237 =10483 built
230CID L6 1BBL, Bore/Stroke 3,25/4,63 inches, Compression Ratio 8,00 to 1, 138HP/4000RPM, 208LBS.FT/1600RPM
2142 = 2door Sedan = 3530 Lbs = $2262 = 21132 built
2145 = 4door Sedan = 3620 Lbs = $2337 = 60810 built
2146 = Lancer 2door Hardtop = 3570 Lbs = $2357 = 44397 built
2149 = Lancer 4door Hardtop = 3665 Lbs = $2436 = 13619 built
2143 = Lancer Convertible = 3815 Lbs = $2600 = 3363 built
2147 = Suburban 2door Station Wagon, 6P = 3830 Lbs = $2618 = 7163 built
2148 = Sierra 4door Station Wagon, 6P = 3930 Lbs = $2697 = 13033 built
2168 = Sierra 4door Station Wagon, 9P = 4015 Lbs = $2815 = 4019 built
325CID V8 2BBL, Bore/Stroke 3,69/3,80 inches, Compression Ratio 8,50 to 1, 245HP/4400RPM, 320LBS.FT/2400RPM
Royal
Series D67-1. Wheelbase 122 inches. Built 40999 units.
2175 = 4door Sedan = 3620 Lbs = $2479 = 19923 built
2176 = Lancer 2door Hardtop = 3585 Lbs = $2532 = 12252 built
2179 = Lancer 4door Hardtop = 3690 Lbs = $2578 = 8824 built
325CID V8 2BBL, Bore/Stroke 3,69/3,80 inches, Compression Ratio 8,50 to 1, 245HP/4400RPM,320LBS.FT/2400RPM
Custom Royal
Series D67-2 / D71. Wheelbase 122 inches. Built 54869 units.
2285 = 4door Sedan = 3690 Lbs = $2637 = 18135 built
2286 = Lancer 2door Hardtop = 3670 Lbs = $2637 = 15632 built
2289 = Lancer 4door Hardtop = 3750 Lbs = $2739 = 11430 built
2283 = Lancer Convertible = 3810 Lbs = $2883 = 2456 built
2288 = Sierra 4door Station Wagon, 6P = 3960 Lbs = $2827 = 4162 built
2298 = Sierra 4door Station Wagon, 9P = 4030 Lbs = $2947 = 3054 built
325CID V8 4BBL, Bore/Stroke 3,69/3,80 inches, Compression Ratio 8,50 to 1, 260HP/4400RPM, 335LBS.FT/2400RPM.
Posted 2019-08-06 11:11 AM (#585711 - in reply to #585677)
Does the Convertibles was Lancer nameplate?
LD3 Greg
Posted 2019-08-06 11:15 AM (#585712 - in reply to #585677)
Hi Igor,
We were doing a list of D500s only. I was looking for actual car examples not just literature.
Thanks,
Greg
LD3 Greg
Posted 2019-08-06 11:18 AM (#585713 - in reply to #585711)
frwl - 2019-08-06 11:11 AM
Yes. Any models of Convertibles and hard tops.
Greg
arizona mopar gold
Posted 2019-08-07 5:21 PM (#585766 - in reply to #585677)
500
Hi guys,
Here are the Engine and Data Tags off my 57 D500's
I only have 4 of my cars here...the 5th is still pending pickup. As soon as it arrives here in AZ I will get the details off it
VIN in order of tags are
38012561 = Sierra Wagon
37269761 = Royal sedan
45542261 = Custom Royal Lancer
35291395 = Coronet Lancer
Wow...just noticed 3 VINs ending 61 !!
Edited by arizona mopar gold 2019-08-08 2:13 AM
(20190807_140014_resize_22.jpg)
(20190807_135822_resize_86.jpg)
(20190807_140151_resize_90.jpg)
(20190807_140134_resize_70.jpg)
(20190807_140041_resize_32.jpg)
(20190807_140055_resize_53.jpg)
(20190807_141200_resize_56.jpg)
(20190807_140218_resize_87.jpg)
Attachments 20190807_140014_resize_22.jpg (163KB - 408 downloads)
Attachments 20190807_135822_resize_86.jpg (187KB - 382 downloads)
Attachments 20190807_140151_resize_90.jpg (213KB - 385 downloads)
Attachments 20190807_140134_resize_70.jpg (174KB - 402 downloads)
Attachments 20190807_140041_resize_32.jpg (178KB - 373 downloads)
Attachments 20190807_140055_resize_53.jpg (178KB - 412 downloads)
Attachments 20190807_141200_resize_56.jpg (183KB - 427 downloads)
Attachments 20190807_140218_resize_87.jpg (184KB - 392 downloads)
LD3 Greg
Posted 2019-11-02 4:40 PM (#589626 - in reply to #585677)
Bump
LD3 Greg
Posted 2019-11-07 2:06 PM (#589865 - in reply to #585677)
Here are 5, 57 Dodge D500s that Carl Kiekhaefer ordered in 1957.
37246906, CR 2 Dr HT, KD500-1689, 10/31/56
37250192, CR 2 Dr HT, KD500-2262, 11/14/56
37263198, CR 2Dr HT, KD500-4835, 12/21/56
37263206, CR 2 Dr HT, KD500-4824 12/21/56
37319022, CR 4 Dr Sedan, KD500-18754, 8/15/57
This info courtesy of Karl Pippard. Thanks, Karl.
Greg
tallzag
Posted 2019-12-01 3:34 PM (#590978 - in reply to #585677)
I own:
35217428 2 Dr HT, KD500-8801 2/7/57
Has the original engine in it.
(IMG_E1606s.jpg)
Attachments IMG_E1606s.jpg (83KB - 342 downloads)
tallzag
Posted 2019-12-01 3:35 PM (#590979 - in reply to #585677)
Can anyone help decode the IBM card? Looks like a pretty low option car. Was sold new in Cedar City, UT.
Posted 2019-12-01 4:18 PM (#590982 - in reply to #585677)
100025
Tom, can you say what is the dealer name?
Posted 2019-12-01 4:27 PM (#590983 - in reply to #590979)
tallzag - 2019-12-01 12:35 PM
LD3Greg is your man. In the meantime, some of this might help you figure things out:
(KD500_8801.jpg)
(ictfatboys57DodgeBuildSheet_CleanedAndAnnotated.jpg)
(NeilAndGregsBuildSheet_larger_Turned.jpg)
Attachments KD500_8801.jpg (183KB - 334 downloads)
Attachments ictfatboys57DodgeBuildSheet_CleanedAndAnnotated.jpg (144KB - 379 downloads)
Attachments NeilAndGregsBuildSheet_larger_Turned.jpg (196KB - 385 downloads)
tallzag
Posted 2019-12-02 7:42 PM (#591026 - in reply to #585677)
Dealer was Lunt Motor Company.
Posted 2019-12-03 11:07 AM (#591039 - in reply to #585677)
100025
thanks, this is the dealer code number
(54409.JPG)
Attachments 54409.JPG (59KB - 360 downloads)
fast59desoto
Posted 2019-12-04 9:22 AM (#591066 - in reply to #585677)
50010010010010025
I Have a 57 d500 2dr wagon
ill get the numbers off it soon
LD3 Greg
Posted 2019-12-04 10:04 PM (#591088 - in reply to #590979)
tallzag - 2019-12-01 3:35 PM
Tom,
I suppose you said it was poorly optioned because it didn't have PS or PB. Aside from that it is nicely optioned. It is a Coronet 2 Dr HT but is coded as a custom coronet with a gray interior. Deluxe two tone paint. Roof, fins and lower are heather green with a glacier white saddle.3.36 to 1 axle, shipped by rail, torqueflite, heater/ defroster, back-up lights, left os mirror, day/ night mirror, music master radio with front mount antenna, handbrake warning light, map and glovebox lights, variable speed wipers, w/s washer, vanity mirror, air foam rear seat, stone shields, plastic steering wheel, spinner w covers, front bumper spuds, carpet, D500 engine, undercoating, 8.00 X 14 wsw tires
Greg
tallzag
Posted 2019-12-07 5:45 PM (#591238 - in reply to #585677)
Thanks Greg!
martinstrohmeyer
Posted 2020-12-22 4:54 PM (#606982 - in reply to #585677)
New User
I'm buying a 1957 Dodge Royal D500 Hemi 325ci 4dr next week. Phoenix AZ. Yellow and white two tone, 75k original miles, original paint.
Marty
(Screenshot_20201222-145310_Gallery.jpg)
Attachments Screenshot_20201222-145310_Gallery.jpg (171KB - 213 downloads)
