Convertible Rear Side Glass Question Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Forgotten 61 |
Veteran Posts: 157 Location: Central New York | do the rear side windows on a convertible crank down all the way? I can't get mine to go down past half way and then stop. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Phil: The answer is probably that they should go all the way down but you might want to remind us about the car you are talking about (??) Year? Make? 56 Dodge: 57 Dodge 58 Desoto: 59 Plymouth 60 Chrysler: 61 Plymouth: Edited by 56D500boy 2019-07-11 5:08 PM | ||
Expert 5K+ Posts: 9672 Location: So. Cal | Your regulator is either mal-adjusted, or your rollers are frozen up. Take the panel off and check it out. Look at the FSM for help with adjusting it properly. | ||
Forgotten 61 |
Veteran Posts: 157 Location: Central New York | Whoops, sorry about that. 1961 Plymouth Fury. It just seems odd that they both go down and stop at the point. | ||
Forgotten 61 |
Veteran Posts: 157 Location: Central New York | I mean stop at the same point. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | That's a common occurrence for a mis-adjusted window. When they aren't adjusted properly, they will bind at some point on the way down. | ||
Forgotten 61 |
Veteran Posts: 157 Location: Central New York | I kind of figured as much. My car looks like the one in the picture above except instead of white with red mine is blue with white. Any tips on taking the panels off would be appreciated. I have an FSM but they don't have a lot of information on convertibles. I don't want to break anything. | ||
Forgotten 61 |
Veteran Posts: 157 Location: Central New York | I don't see any obvious screws or anything like that. Do the panels just lift out.? | ||
Expert 5K+ Posts: 9672 Location: So. Cal | There are a bunch of hidden clips. It is best to use a pronged clip remover to pry the panel off with them, otherwise if you just pull on the panel, the clips will rip the panel. I think there are also 2 screws in the very back of the panel. | ||
Expert 5K+ Posts: 9904 Location: Lower Mainland BC | Powerflite - 2019-07-14 10:03 PM There are a bunch of hidden clips. It is best to use a pronged clip remover to pry the panel off with them, otherwise if you just pull on the panel, the clips will rip the panel. I think there are also 2 screws in the very back of the panel. I think Nathan is talking about the same clips that I used when I made new door panels, as shown here: REFERENCE: 1. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=64288&... 2. http://www.forwardlook.net/forums/forums/thread-view.asp?tid=69434&... | ||
Forgotten 61 |
Veteran Posts: 157 Location: Central New York | That's great info, thanks guys. I trying to figure out how they're attached because as I said, there's no obvious screws on the outside. I'll proceed carefully. Love the pictures !!! | ||
big m |
Expert 5K+ Posts: 7807 Location: Williams California | Often, cleaning the old dried out grease out of the tracks and using a lubricant such as Fluid Film will allow the windows to work again, if the car has been setting for years, If it was restored recently, probably a misadjustment of the tracks. ---John | ||
Forgotten 61 |
Veteran Posts: 157 Location: Central New York | I'm hoping it's something that simple. I'll let you know what I find. Thanks again. | ||
Forgotten 61 |
Veteran Posts: 157 Location: Central New York | Well, I got the panels off and to my delight, all it needed was a good cleaning of the mechanisms and tons of lubrication. Windows are working fine. Thanks to everyone for the help. | ||
