57 Dodge erratic AMP Meter
57RID500
Posted 2019-06-09 11:57 AM (#583150)
Subject: 57 Dodge erratic AMP Meter
On my 1957 Dodge D 500, the dash amp gauge, jumps around in an erratic fashion at speeds over 45 - 50 MPH. However, it acts normal at idle and up to speeds of 45 MPH.
No electrical items are on, for example lights or radio or blower etc. everything is in off position, while the AMP gauge jumps around
Should I rebuild generator? Could it be a voltage regulator or some other issue?
thank you Bob
Posted 2019-06-09 12:12 PM (#583151 - in reply to #583150)
Subject: RE: 57 Dodge erratic AMP Meter
500020002000500100100100100
The gauge is fine. Your issue is with either the regulator or the generator.
Sorry.
57RID500
Posted 2019-06-10 8:58 PM (#583254 - in reply to #583150)
Subject: Re: 57 Dodge erratic AMP Meter
thank you
