300C vs 57 Fury air cleaners
wheelcover
Posted 2019-05-27 12:42 AM (#582555)
Subject: 300C vs 57 Fury air cleaners
To my untrained eye, 1957 Chrysler 300C air cleaners look very close to 1957 Fury air cleaners. Can someone help me understand the differences and distinguish between the two?
ronbo97
Posted 2019-05-27 12:01 PM (#582562 - in reply to #582555)
Subject: RE: 300C vs 57 Fury air cleaners
2000200025
They are identical. Same part number.
Ron
wheelcover
Posted 2019-05-27 3:39 PM (#582569 - in reply to #582562)
That’s easy. Thanks.
Phil_the_frenchie
Posted 2019-05-27 5:34 PM (#582576 - in reply to #582555)
Subject: Re: 300C vs 57 Fury air cleaners
500100100100100
On my parts catalog (1957 canadian) for the cars with 2 air cleaners:
1821 398 for C75-300
1827 429 for Fury
1821 915 for Adventurer
It's curious because the US parts catalog (55-58) give the same part number for Fury and 300C. I doubt that canadian Fury had a special air cleaner !
Edited by Phil_the_frenchie 2019-05-27 5:41 PM
Posted 2019-05-27 5:55 PM (#582577 - in reply to #582555)
5000200020005001002525
There are definitely 2 different air cleaners out there. Actually, there are at least 3 or 4 different air cleaners out there, some have taller inlets and others have shorter inlets. I don't know why they changed them, but they did. From what I have seen, the Chrysler air cleaners have contours on the filter housing, whereas the Plymouth air cleaners have flat housings. This is a flat Plymouth housing.
Edited by Powerflite 2019-05-27 6:04 PM
(57FuryEngine.jpg)
Attachments 57FuryEngine.jpg (148KB - 254 downloads)
Posted 2019-05-27 6:01 PM (#582578 - in reply to #582555)
And this is the contoured Chrysler housing. The contoured housing is the one used on the display 300C engine at the Chrysler museum too.
(300C Engine.jpg)
Attachments 300C Engine.jpg (132KB - 256 downloads)
ronbo97
Posted 2019-05-27 9:15 PM (#582583 - in reply to #582578)
2000200025
There are a total of three different 57 300C / 57 Fury air cleaner housings, as per Wayne Graefen. They all continued to have the same part number. Probably design improvements to resolve issues that arose after production started.
Ron
wheelcover
Posted 2019-05-28 12:44 AM (#582595 - in reply to #582583)
Is there any consensus on what the timeline was for the change in design? I’d be curious if all left the factory looking the same or the change happened in December 1956, this design was a service replacement, etc.
Posted 2019-05-28 10:39 AM (#582608 - in reply to #582555)
It's not like Canada used different air cleaners than the US did. The US catalog just failed to list the different part numbers. It is obvious that the US catalog is fraught with errors as it lists them as 1 part per car. Also '57 Fury without power package is dual quad, but '57 Fury with power package is single four? Doesn't make sense.
wheelcover
Posted 2019-05-29 3:33 PM (#582660 - in reply to #582583)
If I understand correctly, any of the styles referred to would be considered correct if the version a car rolled off the assembly line with is unknown?
Posted 2019-05-29 3:44 PM (#582661 - in reply to #582555)
There are obviously 2 different styles, not including the changes to the inlet length. The question is which one went where because they have no part numbers on them to figure it out. That question is reasonably obvious because Chrysler put the contoured lids on the single 4 bbl upper cars like New Yorkers & Saratogas. Whereas, the flat lids were given to Windsors. There was no reason to change the lid design between these cars as they all function & fit exactly the same. But Chrysler did this as a way of distinguishing between the upper level and lower level cars. So it seems obvious that they would have used the flat housings on the Plymouth and contoured housings on the Chryslers. Also many original cars back up this reasoning. The idea that just because there are errors in the US catalog, that it could have been random is foolish.
(1957-1958-New Yorker Air Cleaner.jpg)
(1957-1958-Windsor Air Cleaner.jpg)
Attachments 1957-1958-New Yorker Air Cleaner.jpg (23KB - 225 downloads)
Attachments 1957-1958-Windsor Air Cleaner.jpg (100KB - 228 downloads)
Posted 2021-05-11 8:21 PM (#611898 - in reply to #582661)
All of the Dodge D501 engines I have seen use the flat lids as well.
(1957 D501s.jpg)
Attachments 1957 D501s.jpg (160KB - 135 downloads)
