326 vs 325 Dodge engine Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
Fin_ish Floyd |
Member Posts: 46 Location: Santa Fe Texas | Does anyone know if the 1959 326 Dodge engine is the same engine as the 1958 325 ? | ||
Expert 5K+ Posts: 9913 Location: Lower Mainland BC | Fin_ish Floyd - 2019-03-21 7:40 PM Does anyone know if the 1959 326 Dodge engine is the same engine as the 1958 325 ? There is this: "Dodge wrapped up their unique V8s in 1958, and joined Plymouth in using A-engines in their 1959 lineup. They asked plant engineers to create a new engine that was larger than their old 325; and thus was born the unique 326 cubic inch A-series V8 — the only A engine with hydraulic valve lifters — by using a larger bore than the 318. It was rated at 255 hp and 350 pound-feet with a two-barrel carburetor. This engine was dropped after just one model year; 1960 Dodge buyers found a 318 under the hood, unless they had ordered something stronger from the B-engine line (which had been optional since the 1958 model year). Both the Dodge 326 and the standard 318, when fitted to Dodge cars, carried the Red Ram name, as the “semi-Hemi” had." REFERENCE: https://www.allpar.com/mopar/a-engines.html | ||
Shep |
Expert Posts: 3400 Location: Chestertown, NY ( near Lake George) | different pistons, if that is what you are asking. | ||
Mopar1 |
Expert Posts: 3035 Location: N.W. Fla. | As 56D500boy said...325 is a hemi based Poly & the 326 is an A Poly, totally different engines. | ||
arizona mopar gold |
Extreme Veteran Posts: 509 Location: Whetstone, Arizona | Dodge used the divorced thermostat housing in the heads cross over tube...were as the Plymouth used the intake manifold water thermostat outlet | ||
Rebels-59 |
Board Moderator & Exner Expert 10K+ Location: .Norfolk..Mafia.. ,England UK | I always thought the 326ci was basically a Bored over 318ci but with Hydraulic lifters.. | ||
mstrug |
Expert 5K+ Posts: 6502 Location: Newark, Texas (Fort Worth) | Yes, 318 Plymouth Poly engine bored to 326 for one year and put in the Dodge. 326 The 326 was launched in 1959. Its actual piston displacement is 325.2 cu in (5.3 L) but it was marketed as a 326 to avoid confusion with the Dodge Red Ram 325. The 326 uses the same 3.31 in (84.1 mm) stroke as the 318, but with the largest bore of any A engine at 3.95 in (100.3 mm). It uses hydraulic tappets, unlike the earlier A engines, and was used in the 1959 Dodge Coronet. https://en.wikipedia.org/wiki/Chrysler_A_engine | ||
Fin_ish Floyd |
Member Posts: 46 Location: Santa Fe Texas | So the 326 retained the same water pump housing as the 325? | ||
mstrug |
Expert 5K+ Posts: 6502 Location: Newark, Texas (Fort Worth) | No, the 315/325 dodge engines were different. http://www.qualityengineeredcomponents.com/?page_id=869 http://www.hiltopautoparts.com/product/nors-mopar-water-pump-1957-6... | ||
Fin_ish Floyd |
Member Posts: 46 Location: Santa Fe Texas | ok, The 326 is a bored out 318 so basically they are the same engine, even the water pump housing. Thanks for your help, Floyd | ||
Fin_ish Floyd |
Member Posts: 46 Location: Santa Fe Texas | Thanks for your help. Floyd | ||
Fin_ish Floyd |
Member Posts: 46 Location: Santa Fe Texas | Thanks for your help, Floyd | ||
Fin_ish Floyd |
Member Posts: 46 Location: Santa Fe Texas | Thanks, Floyd | ||
Fin_ish Floyd |
Fin_ish Floyd |
Member Posts: 46 Location: Santa Fe Texas | Thanks for your help, floyd | ||
Fin_ish Floyd |
