Needed parts for my first forward look car!! Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
brand209 |
Veteran Posts: 117 | So I was lucky enough to get my hands on a 56 savoy, sadly she needs some love as the gentleman I bought it from was restoring it for his wife and she passed away which made him stop and sell the car. Needs- generator or 1 wire alternator that will fit my original brackets with minimal fabrication. Electronic ignition conversion (pertronix?) or just a part number. chrome trim for the bottom hood lip. | ||
brand209 |
Veteran Posts: 117 | I was told the number for the pertronix is part # 1383 gentlemen if anyone needed to know. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | I believe that won't work for you as they require a dual point distributor. The later model 318 electronic distributor will swap right into your motor. If you go that route, I sell a kit to mount an HEI module to the bottom of the distributor. That's what I use on all my vehicles. But if you want to use the Pertronix, I think you need to get a dual point plate to swap into your single point distributor. I haven't used them for a long time though so my info may be old. http://www.designed2drive.com Edited by Powerflite 2019-03-18 10:23 PM | ||
brand209 |
Veteran Posts: 117 | it's listed as a direct fit on their website, but I will contact them for more info. One of the reviews on summit racing also has a 56 savoy ( same as my car) listed as what he installed it on, said it fit perfectly and works great. How do you fit the newer style 318 dizzy on anything special or plug and play? Edited by brand209 2019-03-19 12:02 PM | ||
brand209 |
Veteran Posts: 117 | Also I have an original distributor with the hard lined vacuum off the side and I don't wan't to stray to far from what it is. I will be removing this motor at some point and it is just to nice to mess with to much. I recieved boxes and boxes of original mopar parts with the car including suspension, electrical, and switches it's a time capsule in the trunk | ||
Expert 5K+ Posts: 9672 Location: So. Cal | The newer 318 distributor plugs right in without having to change anything. | ||
brand209 |
Veteran Posts: 117 | It won't have a hard lined hose for the advance on the distributor and I'd rather not buy a distributor right now. What is used to change the fitting over? | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | I might have my original generator from my 1960 Plymouth with 318. Does your car have a V8? Does the generator mount off the end of the passenger side exhaust manifold? I'll see if I still have the generator tonight. | ||
brand209 |
Veteran Posts: 117 | yes sir 277 v8 and mounts on the passenger side of the manifold | ||
brand209 |
Veteran Posts: 117 | here is the review, I also have the autolite distributor "I am really impressed with how easy this kit was to install, how well it fit, and how well it worked. I converted a 56 plymouth with a 277c.i. v8. Easier to put in than points and condenser, no adjustments other than ignition timing, and easier to get than points and condenser. I had to contact pertronix to get the correct application, as the autolite distributor number I was working on wasn't listed, and Summit had it to me next day. Available voltage went from about 10,000 volts, which was causing a driveability problem, to 30,000 as measured on an old Sun scope. The car starts easier, and idles smoother than ever" | ||
jboymechanic |
Expert Posts: 2196 Location: Muskego, WI | Sorry, I don't have the generator, I must have sold it already. | ||
brand209 |
Veteran Posts: 117 | no problem thank you for looking J | ||
HemiSportFury |
Member Posts: 38 Location: SW Colorado | Does the generator have a power steering pump on the rear of it? I have one, not sure what year it's for. | ||
Expert 5K+ Posts: 9672 Location: So. Cal | If it has a green tag on it, it's 12 volt and for '56. If it has a red tag on it, it is 6 volt and for '55 or earlier. | ||
brand209 |
Veteran Posts: 117 | I do not have power steering | ||
RICKYMOPAR |
Veteran Posts: 292 Location: Colorful Colorado skier on the license plate | You can buy a whole HEI distributor aftermarket ... cheaper than you can convert to any thing else. Check ebay! I bought one for a 354 hemi and it's great. still no problems 3 years. Looks like crap, but no towing bills yet. Edited by RICKYMOPAR 2019-03-22 10:44 PM | ||
Expert 5K+ Posts: 5006 | Powerflite - 2019-03-18 10:13 PM I believe that won't work for you as they require a dual point distributor. The later model 318 electronic distributor will swap right into your motor. If you go that route, I sell a kit to mount an HEI module to the bottom of the distributor. That's what I use on all my vehicles. But if you want to use the Pertronix, I think you need to get a dual point plate to swap into your single point distributor. I haven't used them for a long time though so my info may be old. http://www.designed2drive.com
yeah F pertronix use this ^^^ | ||
brand209 |
Veteran Posts: 117 | I'd much rather use my stock distributor and pertronix than buy a whole distributor and his bracket | ||
brand209 |
Veteran Posts: 117 | Guys I got a 6v generator from Big M, I have a 12v system it's a bit rough but if anyone needs it I can send it to you after I get my car squared away i'm not going to ask for any money from it. Edited by brand209 2019-03-28 5:10 PM | ||
brand209 |
Veteran Posts: 117 | passengers side 56, 277 poly exhaust manifold needed | ||
