Location: Hastings Mn | Where can I get the windshield trim clips that hold the trim on the car? I need both the clips on the trim and the clips mounted to the car. The cars I need the clips for are a 61 New Yorker and a 61 Plymouth. The clips are the same for both cars. |
Location: Hayward, Calif | When I did wife's 59 dodge, seems to me I got some of those clips from Gary Goers and some from Restoration Specialties. If you google Restorationspecialties.com , you should come up with what they have. Jerry, (a Minn native, now enjoying Calif weather) |
| The 57-59 ones come up on ebay from time to time, Im not sure if they would be the same as the 60 61s. I've watched them before but where the seller has to relist them, they always diaappear from my list. Ill see if i can find them again |
Location: Hastings Mn | Restoration Specialties has the moulding clips. I'll call tomorrow to see if they also have the body clips. Jerry, I was not too far from you the last week of Jan. I was in Palo Alto picking up some parts for the 61 Ply after visiting my cousin in Fontana. Thanks.
Edited by moparfrank 2019-02-07 8:50 PM
Location: DFW, TX | These folks will probably have what you need, even if it is not listed by specific make and model. They will talk you through describing what you have to select the right ones. Good luck! https://www.rjlautofasteners.com |
