breather pipe for tank
TERENCE
Posted 2019-01-01 3:48 PM (#576106)
Subject: breather pipe for tank
hi everyone .... happy new year ...
I have a 61 plymouth .... i took the tank out for inspections / repair etc .... but now i can't quite remember if there was a pipe on the breather pipe from beyond the little rubber pipe that is located on the end .... any ideas, original or mod's will be great ....
cheers
Posted 2019-01-01 4:07 PM (#576108 - in reply to #576106)
Subject: Re: breather pipe for tank
50002000100100100100
Yup, it is shaped like a hook and it is attached with a little clip to the sheet metal.
Edited by 1960fury 2019-01-01 4:08 PM
TERENCE
Posted 2019-01-07 10:40 PM (#576467 - in reply to #576108)
hi ...yea i knew there was something ... i have the little clip thing thats sort of like a two in one style clip but can't remember the pipe properly .... do you have a photo of one ?
Posted 2019-01-08 9:26 AM (#576486 - in reply to #576467)
TERENCE - 2019-01-07 10:40 PM
No, but I'll try to find one and take a picture.
TERENCE
Posted 2019-01-09 12:33 PM (#576534 - in reply to #576106)
Subject: RE: breather pipe for tank
thanks ... that would be a big help to know what i am looking for
Posted 2019-01-09 3:23 PM (#576542 - in reply to #576534)
Found it:
(ventpipe1.jpg)
(ventpipe2.jpg)
Attachments ventpipe1.jpg (167KB - 140 downloads)
Attachments ventpipe2.jpg (174KB - 148 downloads)
TERENCE
Posted 2019-01-16 3:42 AM (#576858 - in reply to #576106)
thanks ....sort of don't remember it on the car just can't think of where it would mount to the body and the clip thing i have is different I'll put up a photo tomorrow
Posted 2019-01-16 1:47 PM (#576880 - in reply to #576106)
The clip isn't in the correct position, needs to be turned 1/4. The pipe goes into the axle hump so that the end is located higher that the fuel tank. You will find the hole in the sheet metal.
TERENCE
Posted 2019-01-17 6:40 PM (#576948 - in reply to #576106)
hi well i found the pipe under some equipment .... stoked .... here's a photo of what i have for the moment ... i still haven't found the clip that you have got ...but i have the other 2 in 1 type clip which i think would secure this pipe and the main tank pipe to each other
TERENCE
Posted 2019-01-17 6:51 PM (#576949 - in reply to #576106)
well that did'nt work so well try again ....oh yea there's another little rubber pipe that i'm sure does not belong there but not sure ...
