oil filter
TERENCE
Posted 2018-12-17 12:27 AM (#575368)
Subject: oil filter
hi ... i would like to know exactly howto fit up the canister type oil filter to the 318 poly motor .... i know its as easy as but just not sure which end the rubber seal should go during assembly ie which end of the filter .... also have had a big oil leak from the can seal any advise to fix that would be great ...
Posted 2018-12-17 12:46 AM (#575369 - in reply to #575368)
Subject: RE: oil filter
500020002000500100100100100
Does this help?
(CartridgeOilFilterDiagram.jpg)
(CartridgeOilFilterPNs.jpg)
Attachments CartridgeOilFilterDiagram.jpg (108KB - 152 downloads)
Attachments CartridgeOilFilterPNs.jpg (167KB - 145 downloads)
TERENCE
Posted 2018-12-17 1:55 AM (#575370 - in reply to #575368)
no not really .... my motor is a 61 style and is different to the diagram... I have a Donaldson filter that says it is important to have the neoprene washer on top of the element .... but what is the top when your putting in the filter doesn't seem to complicated and logically i have put it on the face closest to the block as that seals it from the block and keeps the oil within the circulating system .... rather than leaking out between the block and the element .... logic ..
but i have his nasty leak from the main can's rubber seal .... so its either ok the way i have it and the canister is just a bad sealing surface or its somehow pressurizing the canister ... i think the leak is due to a bad contact somehow ....
TERENCE
Posted 2018-12-17 2:06 AM (#575371 - in reply to #575368)
oh just read the instructions again and it says to use the neo-prene washer on the bottom of the element so for me the bottom is the face closest to the block in an up side down position .... logic ?
